20 Most Recent
Lakewood HV-9/C Floor / Box Fan Questions & Answers
What type and size capacitor is required for the Lakewood desktop fan motor model HV-9 C?
way to go tom
posted to HP Compac forum on computers
I moved you and the OP out of computers
that is why noboby can understand you, and then answer wrong.
amazing no>
and yes don;t come back. that is always a good idea (sarc off)
what not ask Lakewood this, it is there fan, not ours,
we dont make fans at fixya, not yet. maybe next week?
there is no lack of hot air here, as is on all forums.
my guess the motor start capacitor is bad.
call lackwood and ask for that or schematic or BOM or parts list
see what they say,
many things now, are throw-away. with no support at all.
ok I google for you
and here the are, ask them, its there design.
http://www.lakewoodeng.com/Category.aspx?cid=1066
Fan started running real slow.
There is a motor capacitor on the fan that is probably going bad...in order to replace this capacitor, you will need to obtain the correct component either from the manufacturer or from an appliance parts center...be sure to hook it up the same way as the old one is hooked up..
Lakewood mini tower fan model mtf-15. The oscillating fan stopped oscillating. How do you repair it?
Whether the fan has a dedicated oscillation motor or is driven by an extended shaft from the main motor, there is usually a button or switch to disengage the oscillating function. If this no longer has any effect the only cure is to dismantle the machine until the fault is discovered and then if a repair is possible - repair it...
Most domestic fans have no spare part support, mechanisms have a limited life and if "handyman" repairs aren't possible it is considered a throw-away item.
