20 Most Recent
Select Brands SC 152 1.5-Quart Slow Cooker Questions & Answers
My cooks essentials technique pressure cooker will
I had no power on my cepc800. Since parts are not available I had my husband tear it apart. If you are not electrically inclined don't try it....the problem in mine was a high temp resistor, which was bad. The problem was solved with a $2.50 resistor from our local electronics store.
The ladies at church continually want to place
Hi Jerry,
The ladies are right.
The appliance is called a steam table, and it operates on the same principle as a double-boiler. The design uses water as a thermal buffer between the heating element and the food, and ensures that the food is kept at food-safe serving temperature (varies by food, but typically over 140F, sometimes over 170F) but won't let the food get hotter than 212F so it doesn't burn or overcook the food.
If it's splattering boiling water, then it's overfilled and you should reduce the amount of water, but only by a little bit. A steam table should NEVER be allowed to run completely dry.
As for the steam getting you when you take out a pan -- that's true, and you do have to be very careful when you remove pans from a steam table.
What does the code oh mean on my new pressure cooker
It means the cooking time is done and you are now in keep heated mode and have been there less than an hour, after an hour it will say 1H, two hours 2H and so on. It scared me because the first time I used it I thought it was overheat and it didnt tell me in the manual that I could find.
My brand new crock pot won't heat up
maybe you can try checking the electrical cord, check the appliance controls if it has a thermostat test the heating element and if it still proves faulty carry it back and replace it
