20 Most Recent
Vulcan VG260 Gas Kitchen Range Questions & Answers
6 burner propane fed will
I need more information, but I suspect you may not have a large enough regulator on your propane line. The only way to know for sure is to attach a gauge called a manometer onto the manifold that feeds the gas burners. There is a 1/8 inch pipe fitting on the manifold for this purpose. It should read 10 inches of water column. You need a capacity to run about 300,000 BTUs when everything is on at the same time. This requires a large capacity regulator. Also the line from the regulator to the range should be at least 3/4 inch pipe.
