20 Most Recent
Royal Sovereign White 1200 BTU/12,500 Heating Air Conditioner Questions & Answers
Water leaking in the inside of home.
Air conditioners take the moisture out of the air. When the air passes through the coils on the evaporator, they are cold. This causes the air to condense and water to form on the coils. It then drips off into a pan. When the pan is full if it is not drained, you will have an overflow and things get wet. How much water the unit collects depends on how much humidity is in the air, how much air you are moving through the coils and the temp of the coils.
Why wont mmy royal sovereign 904ec turn on
Does the display work or nothing at all?
If nothing at all, check your outlet.
Also, there may be a fuse or circuitbreaker inside the air conditioner that needs to be reset or replaced. Unplug the unit before attempting to find or replace.
If the display works, did you empty the water? Is it upright and level?
