20 Most Recent
Kaz 4100 1 Gallon Humidifier Questions & Answers
I wanted to clean the inside of the kaz vaporizer
I want to clean the white gritty minerals from the fly wheel inside the humidifier. I took the three screws out but the plastic wheel will not move. I'm afraid to force it...might crack or break.
11/13/2013 11:09:30 PM •
Kaz 4100 1...
Answered
on Nov 13, 2013
I have a healthist humidifier
If you've been using tap water, then you likely have hard water deposits (scale) on the heating element, which will eventually cause it to stop working. Try cleaning it with an overnight vinegar soak, or whatever is suggested in the manual if you have one. Once most of the deposits are gone, it shold work again. In the future, this will not happen if you use distilled (not to be confused with filtered) water. Good luck!
How do i clean
How do I clean white gritty minerals from under plastic wheel. I took out the three screws, but the wheel will not move. I'm afraid to force it...might crack or break.
Lost the manual.
Can tap water
We have had a separate make for years and just use tap with no problems.It leaves a water mark on the water holder but it cleans off.If you have a water filter already on your tap or a Brita type container with a filter,feel free to use that too.Either way,it will not hurt the humidifier. Good luck! Greg
I can't see my vapor.
Suspect that you may need to run white vingar through it and clear the atomizer. You should see mist all the time even when the humidity level is reached.
I need a kaz steam
How many watts does
Kaz Steam Vaporizer Safeguard Model 76 use???? I think it's using a lot of electricity. Anyone with clarity please?
