20 Most Recent
Ace Hardware ML250TPA Infra-Red Wall Mounted Panel Heater Questions & Answers
I was wondering where i
Try Procom Customer Service at 877-886-5989. Or call Kozy World at 800-776-9425 and tell them you have a KWP324 (same as ML250TPA).
Heater doesnt stay on when the temp gets colder
Ventless heaters such as these have an oxygen depletion sensor that monitors O2 levels at the burner and shuts the unit off if it drops below a certain percentage (assuming that there will be carbon monoxide production). Check your owner's manual for any requirements such as a window or door needing to be open while this heater is in use.
There also is the possibility that there is water in the regulator of your propane line (if it is outside) that freezes and inhibits the regualtor's function.
Hello
How can I disassemble my
Why do you need to dismantle this? Some of these types of cooler do not have replaceable parts inside. They are usually classed as a "Throw away" machine. It is often easier and cheaper to replace it than repair it.
4/9/2024 1:31:04 PM •
Heating &...
Answered
on Apr 09, 2024
Homebasix Olliscating parabolic heater how to reset
o reset your Homebasix Oscillating Parabolic Heater, follow these steps:
Unplug the heater from the power source.
Locate the Manual Reset Button on the heater. It's usually a small button or switch.
Use a fireproof, non-conductive rod (such as a wooden stick or plastic tool) to press the Manual Reset Button.
After resetting, plug the heater back in and check if it functions properly.
Remember to ensure that there are no flammable objects within 3 feet of the heater and that it is placed on a stable surface.
4/7/2024 11:23:24 AM •
Heating &...
Answered
on Apr 07, 2024
