20 Most Recent
Haier Amana Apn14j-E Portable Air Conditioner Questions & Answers
Amana apn14j-e stops working after a few minutes
More likely the pipe sensor is defective (a sensor inside the evaporator ,connected to the thicker gas line).... if it don't send any temperature changes to the control board after 5 minutes , it believes the A/C isn't working and cuts off the whole thing to safeguard the compressor from damage ....
Haier mini split E7 and exterior fan not working
On a Haier Split system a E7 error is a failure of the outdoor inverter PCB and the outdoor power supply PCB. Both will need replacing. Looking around $600 for those parts. Plus fitting. The indoor PCB is very unlikely to be needed.
Where is the drain hole
Hello, some window units do not have a drain hole for the condensate, instead the use the fan blade to sling the water on the condenser, since the condenser is warm/hot it will evaporate the condensate.
