20 Most Recent
Whirlpool RF368 Electric Kitchen Range Questions & Answers
Gr399lxg f1 e2
E2 F1 - UL A/D error(s)1. Disconnect power longer than 30 seconds.2. Re-apply power and observe for longer than 1 minute.3. If failure remains, disconnect power, replace control.Here is the board to order.The part comes with a 365 day, any part, any reason return policy.
Removing interior light cover
The cover is normally a flat piece of glass with clips either side or a round glass knob. Push the clips out of the way and the glass should come off with a little tap. The glass knob unscrews. Sometimes hard to turn. Dont be scared to use multigrips as it is quite tough just be gentle.
Whirlpool electric oven stopped working after
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%&*TR
Kenmore F@ error beeping
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Need to remove the cover for the oven light - it
If the owners manual says it unscrews try heating the oven up a bit to expand the steel and carefully use an oven mit to try to remove it. WORD of caution is to UNPLUG or disconnect power to the stove before you horse on it to avoid crossing any wires at the back of the stove should the whole assembly twist on you and cause damage to your control board.
No 115v to oven light or switch
as per the problem you indicated it can be either the faulty
wirings or the faulty switch.check the
wirings with a continuity tester.
you can get required parts from
www.repairclinic.com
click on this link directly for more detailed help to troubleshoot the problem
http://www.applianceaid.com/elecrange.html
This will help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya
Light bulb
It just turns counterclockwise to come off. Sometimes it is very hard to turn them. If you have a strap wrench you could try that.
Whirlpool electric range won't work
We read on another site that sometimes an electical surge messes something up and that if you unplug the range for a few minutes it will reset. So we unplugged our range and when we plugged it in again it worked fine.
