20 Most Recent Desa International ReddyHeater® R115DT Utility Questions & Answers
I have a RH200T, I
you must switch back to kerosene diesel isnt as clean and wont alow it to lite
1/27/2011 12:56:22 AM • Desa... • Answered on Jan 27, 2011
Need fan motor pn#097134-02
chris_mccrar,
Try http://www.reddyparts.com. If anyone has it they will.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
1/13/2011 2:30:20 AM • Desa... • Answered on Jan 13, 2011
2answers
The heater shuts off tripping the reset- motor/fan ***'y is froze
097134-02 try Reddy Parts
1/9/2011 7:31:38 PM • Desa... • Answered on Jan 09, 2011
My heater's motor turns, the ignitor heats up but
The air line that comes from the motor/pump needs to go to the front hose barb on you nozzle adapter, and the rear line on the nozzle adapter goes down to the fuel tank.
The pump pressure should be about 5.3 or more so your pump pressure is low and this would cause the unit not to work.
Here is a link to a service manual.
http://www.desaparts.com/hsi.html
Make sure you check the rear plastic cover for any cracks and make sure you are not looking pump pressure.
You can also call our service department at 1-877-475-5660 or contact us at www.allpartsinc.com
12/28/2010 2:44:45 AM • Desa... • Answered on Dec 28, 2010
My heater does not ignite
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
12/9/2010 5:13:43 AM • Desa... • Answered on Dec 09, 2010
We have a reddy heater pro 115 kerosene heater.
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
10/31/2010 5:46:34 PM • Desa... • Answered on Oct 31, 2010
Hey my heater when i turn on is the fire for a 5
Check the air filter the fuel level, fuel filter and the fan tightness, this should rotate smoothly.
12/18/2009 6:17:10 PM • Desa... • Answered on Dec 18, 2009
Motor humms, motor only truns by hand
Have the start/run capacitor checked.
12/16/2009 12:54:04 AM • Desa... • Answered on Dec 16, 2009
R150B Kerosene Reddy Heater-
Neither of you state the model of heater that is giving you starting problems. many of the motors have an external starting capacitor (relay). If so, you may just need that part, if your heater is equipped with one. On the other hand, many have an internal capacitor , which is not servicable.
12/1/2009 11:14:25 PM • Desa... • Answered on Dec 01, 2009
I need someone to come out and service our heater.
If its the knob on the gas valve that shouldn't affect the operation however this part is normally not available to the average consumer and I would suggest you have a technician come out
10/26/2009 1:51:53 PM • Desa... • Answered on Oct 26, 2009
2answers
I plugged in my heater this year and nothing......
Mske sure the rape switch is depressed and the heater is sitting upright on a solid surface. Good Luck _Ned_
9/27/2009 12:03:13 AM • Desa... • Answered on Sep 27, 2009
Hello. I have a Ready
Here is a link to your owner's manual... http://12.153.20.74/manuals/099176-01J.pdf. I suggest you go online to www.masterparts.net or call them toll free at 800-446-1446. They should be able to assit you in getting your parts. I hope this helps!
5/21/2009 4:14:11 PM • Desa... • Answered on May 21, 2009
Troubleshooting reddy heater 115,000btu
Remove the nozzle and clean it. Clean the photo cell also. Check the fuel pump pressure it should be 5.1 #.
2/9/2009 9:18:18 PM • Desa... • Answered on Feb 09, 2009
2answers
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
2/9/2009 9:12:53 PM • Desa... • Answered on Feb 09, 2009
Heater will not light
I had similar problems with a older Reddy Heater. I bought a 0-15 lb. gauge and removed a plug on the control end of the heater. Turn on or plug it in and set the fuel line pressure as listed on the data sheet (also listed on the heater).
IMPORTANT. This type of heater will not light if the oxygen level is below safe limits. You need more that 14% to support life. Normal is 21%.
1/25/2009 11:01:46 AM • Desa... • Answered on Jan 25, 2009
My reddy heater works but its kickin out to many fumes
It needs to be tuned up and nozzle changed. also electrodes will need to be cleaned and set.
12/25/2008 6:20:42 PM • Desa... • Answered on Dec 25, 2008
I have a reddy heat
check for a wire getting piched or pierced by a screw or the cowling. If not look for an air flow pressure switch and be sure it is working.
12/18/2008 9:01:58 PM • Desa... • Answered on Dec 18, 2008
Reddyheater r100
the fan must be hitting th upper cowling. see that the fan bracket is fully seated in the cutouts in the lower half of the unit.
12/28/2007 12:52:33 AM • Desa... • Answered on Dec 28, 2007
The middle of the five upright ceramic tiles that house the flame puts off a bright yellow flame.
http://www.fixya.com/support/t26881969-vanguard_ventless_heater_won_t_shut_off Feb 7, 2018 - If it does not work for you, you will need to replace the gas valve. It's expensive but I'm about positive that cleaning it will fix it. ... Hi it is blue with a slight yellow tip ... at www.desatech.com , then go to "Wall Heaters" then click your model ... I fixed this by dismantling the fire and right next to the control knob ... Gas wall heaters vangaurd model VP2600C 10 answers Jan 31, 2014 SOLVED: I have a vanguard propane wall heater, 5 ... 2 answers Jan 6, 2010 More results from www.fixya.com
2/28/2019 7:18:56 PM • Desa... • Answered on Feb 28, 2019
Desa International ReddyHeater® R115DT Utility Logo
28 questions posted
Top Desa International Heating & Cooling Experts
Paul Carew
john h
Jay Finke
Jay Finke
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Desa International Heating & Cooling
Most Popular Question
hey heater when turn fire 5
  • Heating & Cooling
