20 Most Recent
Comfort Zone CZ-530 Compact Heater Questions & Answers
Cz 500 shuts off and comes back on in about 5
Heaters have
)Tip over switch If the heater is thermostatically controlled then what you may have is the thermostat cycling just as a central heating system in your home. When heater reaches the temp you set it shuts off, then comes back on when temp drops several degrees below setting. Yes, It is normal. Ned
2)Thermostat
On & off switch fell
If there are only two wires going to the switch you can unplug the heater and strip about 1/2 inch of insulation off of the wires and twist them together. Use a wire nut or electrical tape to protect connections.
If you can't find the right replacement switch you can use a simple toggle switch in it's place. Or just unplug it when you're done using it. I hope this helps you. Thanks.
Quit working
Based on the limited info.I have, it sounds like the heating element is not getting power. suggest visually inspecting the switch and thermostat for burnt wires. Also check the heating element for broken electrode.
E1 error code on a cz220 comfort zone model heater what does it mean
The E1 error code on a Comfort Zone CZ220 heater indicates a problem with the high-temperature limit switch. This switch is a safety feature that shuts off the heater if it overheats.
To clear the error code, you can try resetting the heater by unplugging it from the power outlet and waiting for at least 30 seconds before plugging it back in. If the error code persists, it may indicate a more serious issue with the heater that requires professional repair.
Comfort Zone CZ230ER doesn't cool down to setpoint and shuts off
If your Comfort Zone CZ230ER is not cooling down to the setpoint and shutting off, there could be several potential issues causing this problem. Here are a few things to check:
- Check the air filter: A dirty or clogged air filter can restrict airflow and cause the unit to overheat. Be sure to clean or replace the air filter as needed.
- Check the thermostat: If the thermostat is faulty, it may not be accurately sensing the temperature in the room, which can prevent the unit from cycling properly. Try replacing the thermostat to see if that resolves the issue.
- Check for leaks: If the refrigerant level is low due to a leak, the unit may not be able to cool properly. Have a professional inspect the unit for leaks and repair them as needed.
- Check the compressor: If the compressor is faulty, it may not be able to properly circulate refrigerant through the system, which can prevent the unit from cooling. A professional will need to diagnose and repair any issues with the compressor.
- Check the fan motor: If the fan motor is not functioning properly, it can prevent the unit from properly circulating air, which can cause it to overheat and shut off prematurely. Check to see if the fan is running smoothly and replace the motor if necessary.
If you are unsure how to perform any of these checks or repairs, it's best to consult a professional HVAC technician.
