20 Most Recent Quantum 610 Scooter Power Wheelchair Color: Blue Questions & Answers
I have an older quantum 600 chair when i turn on chair 2red light keep flashing in bottom of charge in seat tilt work and horn but motors wont work
What is the position of your Manual Freewheel Levers? If they are DOWN the Freewheel is engaged, the motors will not work. Pulling BOTH Freewheel Levers fully UP should solve the problem. 1-3xr3ikeczdyorn0jjgkjfpd3-1-0.jpg
10/10/2023 5:01:35 AM • Quantum Health &... • Answered on Oct 10, 2023
Put a used controller on my Quantum chair. It lights up but wont go. Has a picture of a chair with a square beside it but won't go?
That's the problem with buying used parts as they take a chair that doesn't work properly and see the parts off., even the part that caused it to fail and be sold or scrapped. Send that part back and buy new. But what if the controller is not the issue though. No model given, just the maker. Add the model to his search query. https://www.google.com/search?q=Quantum+chair+%22service+manual%22 ..
9/17/2023 1:18:35 AM • Quantum Health &... • Answered on Sep 17, 2023
Quantum edge wheelchair joystick-controller suddenly does not light up or turn on. New batteries three weeks ago was working fine.
even if the battery was replaced recently check if it is damaged or depleted. also, the battery connection could be loose.
8/21/2023 4:08:18 PM • Quantum Health &... • Answered on Aug 21, 2023
I have a 6000z quantum wheel chair and cannot find how to get rear battery out
It comes out the front also.....but it is a real pain if the cabling was put on with out any thought the last time they were replaced. I had to hire a neighbor hood teen ages to get down and "walk" the battery out by rocking it back and forth.
5/18/2022 1:21:47 AM • Quantum Health &... • Answered on May 18, 2022
Pride Mobility Quantum 600 Mobility Scooter. Error message 'Brake 1 disconnected' help please!!
Question edited for clarity. Error: Brake 1 not connected Brake 1 error detected 1. Turn power off 2. Disengage then re-engage brake lever 3. Inspect motor connections 4. Turn power on https://www.pridemobility.com/pdf/owners_manuals/operation_instructions/fault_list-q-logic-3.pdf .
10/30/2021 1:20:57 AM • Quantum Health &... • Answered on Oct 30, 2021
Quantum 600 turns to slowly how can i fix that
how to program power wheelchair - YouTube https://www.youtube.com/watch?v=uFG2rReDc-4 25 Nov 2015 ... It feels like it is stalling but just chugs back slowly. ... Does anyone know the fix? ... Can you please tell me what is going on with my titan power wheelchair i turned off and it turns on byself ... i have a jazzy chair. when i plug in the controller then turn it on, it runs ... Quantum Tech HD Recommended for you.
1/24/2020 12:11:55 PM • Quantum Health &... • Answered on Jan 24, 2020
I have an quantum edge 10. it has an error screen of a chair with an arrow pointing to it. it is fully charged, but will not move. i bought it second hand and it has not been serviced since.
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manuals
8/15/2019 3:33:00 AM • Quantum Health &... • Answered on Aug 15, 2019
Quantum eye level 3 wheel chair 6 mile doesnt work only 4.5 does
You will need to contact the manufacturer for support. As far as I know the QE level 3 is available in 4.5 not 6.
6/22/2019 1:01:38 AM • Quantum Health &... • Answered on Jun 22, 2019
My quantum q6 edge mobility chair is stuck in slow mode how can i change this
PDF]
QUANTUM Q6 Edge Series - Pride Mobility
https://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_q6_edge_om.pdf
Including Models: Quantum Q6 Edge 3S, Quantum Q6 Edge 3SP, and Quantum Q6 .... Do not place your power chair in freewheel mode while on an incline or decline. ... Do not modify your power chair in any way not authorized by Pride. .... Regenerative - uses electricity to rapidly slow the vehicle when the joystick returns ...
2/20/2019 7:18:37 PM • Quantum Health &... • Answered on Feb 20, 2019
On my quantum q6 edge power chair I'm receiving a error code 224 can you tell me what this means?
hi, can't find that error code , do you mean 24 ? What joystick ( controller ) is fitted ? https://www.quantumrehab.com/quantum-electronics/ne-controller.asp Regards Rob
11/14/2018 10:38:18 PM • Quantum Health &... • Answered on Nov 14, 2018
Its Quantum Q6 edge. I got this error today. Please tell any solution.
First, I'm not a Quantum epresentative. * Check your warranty. Call for support. USA:Pride Mobility Products Corporation Attn.: Customer Care Department 182 Susquehanna Avenue Exeter, PA 18643-2694 [email protected] 1-800-424-8205 *** Following is for information only.*** * Manual; https://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_q6_edge_om.pdf * Follow guidelines in manual (especially charging and maintenance) * Check your fuse. * As with most Lead Acid battery systems. Care must be taken to assure long life. * Lead acid batteries have a cycle (recharge) about 200-500 cycles. * Example, if you charge every day that's 1 cycle per day for 200 to 500 days. Depending on how hard you drain the batteries, charge times, and how hot it gets where you store it. * Here in Hawaii, most car batteries last 2-3 years tops. For power chairs it's less. (I suspect it's due to having lots of hills.) * You will need to check the status (Health) of your batteries. (Take it to the shop to test. Battery shops can test it too.) Aloha, ukeboy57
8/19/2018 11:26:09 PM • Quantum Health &... • Answered on Aug 19, 2018
Quantum 610 Scooter Power Wheelchair Color: Blue Logo
2 questions posted
Top Quantum Health & Beauty Experts
ADMIN Andrew
ADMIN Andrew
Jesse Walters
Jesse Walters
jws1013
Are you a Quantum Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Quantum Health & Beauty
Most Popular Question
q edge 3 chair recently began giving
  • Health & Beauty
