20 Most Recent Whirlpool GR448LXPQ Electric Kitchen Range Questions & Answers
0answers
0answers
Ovennotworking
Be the first to answer 2/12/2014 10:40:32 PM • Whirlpool... • Posted on Feb 12, 2014Be the first to answer
Location of the fuses
GR448LXPQ
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GR448LXPQ
Click on your model number. Click on the diagrams in the left-hand side for the parts location.
A thermal fuse (9) is shown in the Chassis Diagram. You can check that and other diagrams for more.
11/8/2013 6:36:00 PM • Whirlpool... • Answered on Nov 08, 2013
Can you just replace the start button or do you
Hi, there. While we cannot assist with repairs I can offer links to our troubleshooting, use and care guides, replacment parts, parts lists, and service line should that be necessary. We hope this helps. http://bit.ly/zkfnZd http://bit.ly/112Lu7q http://bit.ly/LrNZiS http://bit.ly/yLv4Z5
10/14/2013 6:49:20 PM • Whirlpool... • Answered on Oct 14, 2013
STOVETOP WORKS, OVEN WILL NOT HEAT
you probably have a blown thermal fuse. its located behind the unit. just remove the back panel and you will see it.
7/18/2011 1:24:51 PM • Whirlpool... • Answered on Jul 18, 2011
My range got so hot the cooktop exploded. Has
I was in the appliance repair service for over 40 years and I have seen this happen a few times.Why it happens I don't know. All you can do is check the cost of repair and decide to repair or replace entire range.Hope this answers your question.
6/21/2011 12:53:42 AM • Whirlpool... • Answered on Jun 21, 2011
I have a whirlpool gr448lxps-1 range the oven will
Most of the time the replacement instructions will come right with the part...not to worry though once you get it you will see easily how it goes... it is easy to do...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
12/16/2010 2:58:34 AM • Whirlpool... • Answered on Dec 16, 2010
The oven takens forever to heat to right temp. It
new elements
10/14/2010 4:39:16 AM • Whirlpool... • Answered on Oct 14, 2010
When I try to use the self-cleaning feature on my
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$&U*%I*RY
10/1/2010 3:58:08 AM • Whirlpool... • Answered on Oct 01, 2010
Start button does not work on whirlppol range
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^&UG
10/1/2010 3:57:30 AM • Whirlpool... • Answered on Oct 01, 2010
Self cleaning e1 f5
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$
10/1/2010 3:56:45 AM • Whirlpool... • Answered on Oct 01, 2010
Whirlpool GR448LXPQ Electric Kitchen Range Logo
55 questions posted
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Kitchen Ranges
Most Popular Question
start button not work whirlppol range
  • Kitchen Ranges
