20 Most Recent AT&T ATT-992 Corded Phone Questions & Answers
How can I clear the
You can always unplug it and remove the battery for 10 mins, that will clear everything. If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
5/18/2014 8:39:25 PM • AT&T ATT-992... • Answered on May 18, 2014
0answers
Phone is on mute
Hit the mute button and it should turn off...
2/4/2014 6:08:28 PM • AT&T ATT-992... • Answered on Feb 04, 2014
Cannot record outgoing voicemail greeting
It's not in the manual for the good reason that the AT&T 992 isn't an answering machine. If you want to record an outgoing voicemail greeting, you'll have to do it on the voicemail system, not on the phone. If you need instructions on how to do that, you'll have to tell us the make and model of the voicemail system or answering machine.
11/25/2013 5:57:30 PM • AT&T ATT-992... • Answered on Nov 25, 2013
Record an outgoing voicemail greeting
11/25/2013 5:56:44 PM • AT&T ATT-992... • Answered on Nov 25, 2013
Record outgoing voicemail greeting
The AT&T 992 isn't an answering machine. If you want to know how to record an outgoing voicemail greeting, you'll have to tell us the make and model of the voicemail system.
11/25/2013 5:55:53 PM • AT&T ATT-992... • Answered on Nov 25, 2013
0answers
I lost time on my
Feature ** 266344266344 is probably the password. Hit next until you see Time and Date, hit show and you can change it.
1/20/2011 9:29:04 PM • AT&T ATT-992... • Answered on Jan 20, 2011
Pluged in the ATT 992
Hi Dewey,
Please make sure that the mute light is glowing when you are in the call as this will your microphone mute so your voice will not be heard at the other end.
1. Mute allows you to hear the other party, but the other party cannot hear you.
2. To activate this feature, press and release Mute button.
The MUTE light goes on.
3. To return to the conversation, press and release Mute button again.
NOTE: Switching from handset to speakerphone or headset, or from speakerphone or headset to handset, changing lines, and putting a call on hold will cancel Mute.
If still your voice is not transmitted properly to the other end, there there might be some problem with your phones microphone.
connect the receiver unit from any other similar phone and check. If works well, then its sure that your existing receiver's microphone is not working. To rectify this problem you may need to call for a phone service center.
I hope this is helpful to you
Thanks
5/25/2010 2:47:10 PM • AT&T ATT-992... • Answered on May 25, 2010
2answers
How to clear ALL memory from 4-set of (now disconnected) AT&T Model CL82401??
There is a way to delete all calls in the Caller ID log. With the phone system in standby mode, press Menu/Select (key to the upper right of the arrow keys). Scroll (up/down arrows) to Caller ID log. Press Menu/Select again. Scroll to Del all calls and press Menu/Select. You should see a Delete all calls? Press Menu/Select to confirm. There is no corresponding way to delete all old speed dial or directory listings. The manual for the CL82401 is available here: https://att.vtp-media.com/media/p/document2/products/%7B60627918-4BDE-494D-8537-E265D7649708%7D/CL82201_CIB_2_611.pdf . See page 42 for the information on deleting the caller ID log. See pages 36 and 38 for the directory and speed dial items. I hope this helps. Cindy Wells
12/15/2023 3:52:36 PM • AT&T Lands... • Answered on Dec 15, 2023
2answers
AT&T 1830 phone/answering machine. How do I get a manual please?
Question edited for clarity.
AT&T 1830 User Manual - ManualMachine.com
ManualMachine.com https://manualmachine.com > att > 6453-user-manual ANSWERING SYSTEM TELEPHONE 1830. •Installation. •Telephone Operation. •Memory Dialing. •Answering System Operation. •Remote Operation ...
AT&T Product Manuals ' Product Support Center
AT&T https://telephones.att.com > product-support > manuals Find official user manuals and quick start guides for cordless and corded telephones from AT&T.
AT&T Answering Machine 1830 need manual for at&t 1830
Manuals Online http://phone.manualsonline.com > support > att > need... Aug 9, 2012 - Phone manuals and free pdf instructions. Find the user manual you need for your phone and more at ManualsOnline.
12/13/2023 11:07:52 PM • AT&T Lands... • Answered on Dec 13, 2023
How to register AT&T Synj SB67108 to new base unit SB67138?
Register SynJ SB67108 Handset How to register AT&T Synj SB67108 to new base unit SB67138? To register an AT&T SynJ SB67108 handset to a new SB67138 base unit, you will need to follow these steps:
  1. Make sure the new base unit is plugged in and turned on.
  2. Press and hold the "Menu" button on the handset until the display shows "Menu."
  3. Use the navigation buttons to select "Registration" and press "Select."
  4. Select "Base" and press "Select."
  5. The handset will begin searching for the new base unit.
  6. Once the base unit is found, it will be displayed on the handset's screen.
  7. Select the new base unit and press "Select" to complete the registration process.
  8. The handset should now be registered with the new base unit.
Note: if you have multiple handset you need to register, repeat step 2-7 with each handset.
1/22/2023 6:32:18 AM • AT&T Lands... • Answered on Jan 22, 2023
How do I deregister my AT&T CL82313 handset please?
Question edited got clarity. Video should help, similar model. https://www.google.com/search?q=deregister+my+at%26t+cl82313+handset ..
6/28/2022 4:54:29 PM • AT&T Lands... • Answered on Jun 28, 2022
Where can I get a replacement power cord for a handset dock for an AT&T phone model : TL96217
Try AT&T direct https://telephones.att.com/shop The second link might work, but it is a $28 gamble. The first link says specifically that it isn't for the handsets, but doesn't show the end connector! https://www.google.com/search?q=AT%26T+TL96217%2C+replacement+power+cord+for+a+handset+dock ..
1/14/2022 11:55:24 PM • AT&T Lands... • Answered on Jan 14, 2022
AT&T ATT-992 Corded Phone Logo
Popular Tags
21 questions posted
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
AT&T Lands Phones
  • AT&T Lands Phones
Most Popular Question
clear
  • Lands Phones
