20 Most Recent
GE 27831 2.4 GHz Twin Cordless Phone Questions & Answers
How do i change the incoming message on my phone?
The 27831 isn't an answering machine.
Please refer to the documentation for whatever answering machine you have on your phone line. If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
My answering system and my instructions are all in won't pick up
is the incoming phone line plugged into the answering machine directly? the answering machine should then be plugged into the phone. the signal comes through the answering machine then to the phone. you may have the connections reversed on the answering machine. check those connections.
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
