20 Most Recent
Eclipse SIR-ECL1 SIRIUS Radio Receiver Questions & Answers
2006 factory dodge radio sat quit working
soft reset. get in turn on truck with door shut turn on sat radio on ch 184. turn off radio turn off truck and take keys out. next open door fully for 90 seconds. shut door. turn on truck. turn on radio and have sirius reset it. its called a soft reset.
Have ESN Eclipse radio CD2000
The SID # you need to activate that is displayed in two places. On the unit itself, and on channel 0. Try switching to channel 0 once in Sirius mode, and the SID # should be displayed.
I just bought a 2007 Dodge 3500 Laramie and signed
I bought a used 2008 Ram 1500 SLT Sport; satellite would stay stuck on channel 184 with no sound, etc.
Solution: Disconnect negative wire from vehicle battery; wait 1-hour then reconnect. This clears satellite radio cache (a.k.a. hard reset).
Turn on satellite radion; Call Sirius support to send activation signal. Wait on phone with tech support; may take them 2 - 3 tries to get signal to take on radio.
Reactivated Sirius Radio today. Display shows P1,
Disconnect negative wire from vehicle battery; wait minimum of 1-hour, then reconnect.
Turn on satellite radio, call Sirius tech support to have them resend activation signal. Stay on line with them since it may take them 2 - 3 tries.
Satellite radio (REF) not connecting with Sirius.
Do you have a paid subscription? IF you do, call and have them with your radio's serial number and ask them to 'refresh' your radio to restore the other channels. If you only have channel 184 and CH1, it sounds like you haven't purchased a monthly subscription yet.
Screen will not fully open or close
There are no parts that u can buy as the user to repair this problem, they don't sell any repair parts to the public, you need to have the door auto opener replaced, pull the unit out and send it in for repair to an authorized Ecilpse radio radio repair center.
Antenna hookup 2007 dodge ram
Just take the fakra connector (plastic piece) off and it will be just like the sirius antenna end. Then buy a 10ft extention cable... I've just order mine and will have pics when done
How do i put music on my Eclipse mp3
go to mp3juices.cc and download then go to computer open 2 windows then go to downloads one of the boxes click the mp3 driver and drag over into the file desired by opening and dropping.
What is err_no=0x50000011 - Eclipse Audio Players & Recorders
"err_no=0x50000011" is an error code that may appear on an Eclipse audio player or recorder. This error code typically indicates a problem with the firmware or software on the device. The specific cause of the error and the steps needed to resolve it may vary depending on the model and specific circumstances of the device.
Here are a few things you can try:
- Restart the device: Sometimes, a simple restart can resolve software issues.
- Update the firmware: Make sure that the device has the latest firmware version.
- Check the SD card: If the device uses an SD card, make sure that it is properly inserted and that the card is not damaged.
- check the battery: Make sure that the device has enough battery or that it is plugged in.
- Reset the device: If none of the above steps work, try performing a factory reset on the device.
- Consult the manual: Consult the manual for specific troubleshoot and service information for your Eclipse model.
Hello my eclipse mp3 player will charge but when i take it off the charger it plays for 3 minutes and truns off and i just bought it new what can i do to fix it
It sounds like you are experiencing an issue with your new Eclipse MP3 player. Here are a few things you can try to troubleshoot the problem:
- Make sure that the battery is fully charged. If the battery is not fully charged, the MP3 player may not have enough power to stay on for an extended period of time.
- Check the charging cable and make sure that it is securely plugged into the MP3 player and the charger.
- Check the charging port on the MP3 player for any damage or debris that may be preventing a secure connection.
- Try a different charging cable or charger to see if the issue is with the charging equipment.
- If the issue persists, you may need to contact the manufacturer for further assistance.
I hope this helps! If you have any additional questions or need further assistance, don't hesitate to ask.
Download songs to my mp3
I always download songs use a youtube downloader from youtube.It can not only download videos from youtube but also convert the videos to the right forma tyou want while it is downloading.You can take a try for this
free youtube downloader.
