20 Most Recent
Samsung TV Set Top Box Remote Control Questions & Answers
Hi
We have a DTB-H550F set
Their doesn't appear to be anywhere you can buy a Direct Replacement Remote for this Model. The only option therefore is to buy a Universal Remote Control but these aren't always guaranteed to operate a particular model and you have to go through the process of finding the correct code and even then it may not be 100% compatible. On the plus side they are fairly cheap so probably worth giving it a try.
I need a code for my Samsung tv model
Please rate this solution if you find it helpful. Thanks.
It really depends which version of Sky remote you have. You can check this by looking inside the battery compartment. If you have a sticker with RC1600/00 then it probably wont work your TV. If it says Rev 4, or Rev 6, it might work with this code: 0646
If you have a Rev 8, then try these 3 codes: 1340, 0840 or 0646
Sky's information is a little bit contradictory regarding your particular model of TV, so I don't guarantee success. However, 0840 and 0646 seem to be generic Samsung codes, so I think these would probably control the power and volume functions on you TV if nothing else.
Try the codes above and report back.
I want to record two programs using DTB - how?
I called STRONG & what I wanted to do is not possible. I didn't think my enquiry had gone thru as my credit card details were denied on your site. If it has gone thru please cancel this request for help.
Thank you very much. Regards Brie
How to set up a TV remote control
there are different ways to try to get it to work, you could:
A. press the TV button on the remote before you touched anything else.
B. it really depends on the model remote you have, if its a universal remote you may have to enter a code in before you use it, (which should be in the remote manual) (note: different brand TV's will have different codes)
C. press TV on the remote and turn the TV off using the power button on the remote only. then turn it back on using the power button solely on the remote, this may connect the TV to the remote.
D. some remotes may have you hold down a certain button for a few secs before it will sync up.
When in doubt refer to the manual for the remote.
Samsung HD tv
Your TV should be an output, only the cables are different.
Let me know the exact model of your tv, and what cable you are using to connect it, so that I can give you more information.
