20 Most Recent Equity Time USA Insta-Set 44200 Clock Radio Questions & Answers
That's the radio antenna. Just tuck it under the unit or along the back of the shelf or whatever if you get adequate reception. If you don't then you might try fussing with it--taping it up the wall, draping it over a book, that kind of stuff.
Equity Time USA... | Answered on Oct 17, 2013
Press and hold the "Alarm Set" button for five to seven seconds and the year will begin to blink when the clock is ready for adjustment. .
Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock.
Set the month, day, hour and minute. Press the "Alarm Set" or "DST" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
Press the "Alarm Set" or "DST" button after setting the date and time to store the information into your clock's memory.
Press alarm 2 to change from Celsius to Fahrenheit.
Press alarm 1 to change from 24 hr time to 12 hr time.
Equity Time USA... | Answered on Jan 04, 2013
Hold the Alarm 2 button down to change from Celsius to Fahrenheit.
This may or may not work. The 40009 and 40010 are almost identical. The 40009 doesn't mention military time and the 40010 does, so you might want to what the manual says. 40010 manual and 40009 manual. According the 40010 manual, is says:
Displaying the12/24 hour, Date, Month and Year:
Display the 12/24 hour by hold the "+" button for 2 seconds. To display the date, month and year by press the "-" button, the year appears and then if pressed again, the month and date (eg. “12 31” means Dec 31) appears.
So maybe that will do. I have a 40010, but my manual is different from the one on the website. Its DST button and not Alarm Set button to change the time. So maybe try holding down different buttons for a couple of second see if one lets you change it between 12 and 24 hour. Good luck, hope this helps.
Equity Time USA... | Answered on Oct 07, 2011
This solution from the answers below worked on my model 40007 clock today: If you hold down the button on top that says DST for like 10 seconds it will allow you to force change the time.
Thanks. wd 11/21/2010
Equity Time USA... | Answered on Dec 04, 2010
Equity Time USA Insta-Set 44200 Clock Radio Logo
23 questions posted
Top Equity Time USA Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Equity Time USA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Equity Time USA Audio Players & Recorders
Most Popular Question
insta set model 44200 clock radio just
  • Audio Players & Recorders
