20 Most Recent
RCA RP5440 Clock Radio Questions & Answers
Snooze alarm
Like everyone else here I have accidentally hit the NAP button and couldn't turn it off. This morning at 2am I accidentally hit it with my husband in bed. I decided one and for all to guide this out. By flashlight and my cell phone i Googled a solution. I came across many, none of which worked. I resorted to trying methods that were posted for other models of this brand of clocks. The solution that I found that worked was to hold down the back part of the NAP button until the seat the time displayed and the nap light off. By back part of the button I mean hold down the tiny section closest to the rear of the clock. I got this solution from instructions for model RP3721A clock. It took me 17 minutes.That's just 3 minutes before the alarm would have gone off.
QHL040WLH
HelloIf you are in need for the user manual for RCA RP 5440 CLOCK RADIO, I've the manual with me. I can't send it to you by this window as it does not allow me to upload PDF files by it. If you send your Email ID to me by FixYa, I'll send a copy of it to you by return mail. OK.
Clock is 5-10 behind. How do I reset?
u will have to set the time zone you r in. If u don't know how to do that download the clocks manual from :
http://www.devicemanuals.com/guide/Radio/RCA-manuals.html
Setting the alarm on my clock radio
use the selector switch on the top, switch it to wake 1 or wake 2. set the time that you want that alarm to go off. then push the switch all the way back to the left to deactivate it. then to activate the alarm, use the buttons on top labeled wake 1 or wake 2 to turn the desired alarm on. pushing that button repeatedly will cycle the alarm to either beep, radio, or it will turn that alarm off.
My RCA home theater system,
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
1/15/2024 9:01:27 AM •
RCA Audio...
Answered
on Jan 15, 2024
