20 Most Recent
Teac SRL200i/B Clock Radio Questions & Answers
Curtis
The same problem for me for the iMode iP215... right now, I am going to my cousin's house (he's a technical fixer person) If he can tell me what is the problem, I'll give you guys the answer on how to fix it. If not, I just lost money for nothing.
Right clock time
Hold
the memory button on the remote control, wait for the written "SYNC ON" on display and then
press the track forward (one on the right with the double arrow).
Now normally set the clock.
IMode IP215 Won't Charge iPod 4th Generation
It's because it charges via FireWire and your iPod charges via USB. This 12V vs. 5V. I've encountered this twice recently myself. Scosche makes an adapter that's sold through the Apple Store.
48-08sd50000320 dead
I called iHome today and was told you can buy the circuit board with dock for $13.50 from:
SDI Technology
135 Essex Ave.
Avenl, NJ 07001
You must pay by money order. It is $13.50 which includes shipping. Include a separate piece of paper with name and shipping address, model number and service number of product from tag.
Is the Teac CR-H100 a unit that can be repaired?
The repairability of the Teac CR-H100 depends on the specific issue it's facing. Many electronic devices, including audio units like the Teac CR-H100, can be repaired if the problem is identified and if replacement parts are available. It's recommended to contact Teac customer support or a certified technician to assess the specific issue and determine the feasibility of repair based on the unit's condition.
Teac NP-H750 takes a long time from powering at wall to going into standby / ability to switch on.
Here are some troubleshooting steps you can try: Power source and wiring: Make sure you are using a reliable power source and the correct power cord for the Teac NP-H750. Sometimes using faulty outlets or wiring can slow down the power on time. Firmware update: Check if there is a firmware update for the device. Manufacturers regularly release firmware updates to fix performance issues and improve performance. Updating the firmware can help fix the slow power-on. Reset the device: Try a factory reset on the Teac NP-H750. This process can help eliminate any software bugs that may be causing the slow startup. Network connection: If your Teac NP-H750 is connected to a network, check the network settings to make sure you have no problems connecting to the Internet. Sometimes network issues can delay the startup process. Check for hardware issues: Inspect the device for any damage or loose connections that could cause a delay during power on. Check the power button and other controls carefully for proper operation. Power saving system: Check the power saving system on the Teac NP-H750. If the device is set to quickly go into standby mode, it may take longer to turn the power back on. Use Support: If none of the above solutions work, consider contacting Teac Customer Support or their Authorized Service Center for further assistance. They may have specific troubleshooting problems or know general issues with your model. Please note that products must be made with care, as modifications to the product or unauthorized repair attempts may void the warranty. If your Teac NP-H750 is still under warranty, it is best to contact the manufacturer
