20 Most Recent
LG C1500 Cellular Phone Questions & Answers
LG C1500 phone is stuck on headset mode and no headset is in it.
PERSISTANCE IS KEY!
My Palm Centro sat in a small
puddle for a few seconds, and the only thing that was wrong was that it
was, like every other poster here: Stuck in Headset mode. For 3 days I
read posts / forums all over the place, getting similar ideas about
inserting/pulling out the speaker cord rapidly / soft or hard resetting
/ pulling out at a certain point etc etc.
The real
problem was that inside the 2.5mm jack there is a little microswitch
that enables / disables the headset function, and if it gets stuck
open- nothing can override it. --- Again --- 3 full days of twisting,
pulling out, screwing with the jack and wasn't able to get anything out
of it- was about to say screw it.
THE ANSWER!!! -- I
read somewhere that using a Qtip could increase my chances of snagging
the switch down; I doubled my odds and sprayed the **** out of it with
WD-40 (with the fore-idea that the switch got all gunked up and is
stuck in the open position)
--To test it out, start
playing a music file or anything that should originally go through the
main speaker (or just call your Voicemail)
-- I got the tip wet with the wd-40, and since I have a 2.5mm
jackport (not even the qtip stick fits in the hole) I started twisting
the cotton off of the stick into an elongated portion of the wet
cotton; long enough to fit in the port. I stuck it in (twisting in the
same fashion as the twisted cotton) and just started twisting. About a
minute worth then I yanked out and-- WaLaa! MUSIC
Only
thing that worked in 3 days; I figure the individual cotton strands
snagged on the thing and pulled it down, although I contribute it
finally moving to the WD-40.
GOOD LUCK =)
6/6/2011 1:20:41 AM •
LG C1500...
Answered
on Jun 06, 2011
Trying to unlock LG C1500
you can contact the service provider,they willhelp you to get the unlock code for your mobile
4/19/2011 7:05:13 PM •
LG C1500...
Answered
on Apr 19, 2011
Unlock code for lg c1500
Security unlock lock codes can only be reset by calling your cellular provider
and asking for Tech Support. After answering your security question,
you'll be provided a security code. We do not provide security codes at
FixYa as we are unable to verify the ownership of your phone.
1/30/2011 12:22:51 PM •
LG C1500...
Answered
on Jan 30, 2011
LG C1500
I need the restriction code for LG C1500
8/29/2010 1:49:27 AM •
LG C1500...
Answered
on Aug 29, 2010
My lg ryhthm phone got wet and now its stuck in headset mode
Your phone's headphone jack port is shorting. Try turning the phone off then dry it with a hair dryer for 5 minutes. Turn it back on and see if it helps, if it doesn't well you now have a permanent damage on your phone, its probably the headphone port controller, its busted...
7/14/2010 6:56:59 PM •
LG C1500...
Answered
on Jul 14, 2010
Phone randomly turns off on its own
hi, it could be that the battery is bad....try see if you can change that...Also, it could be that you over loaded the phone beyond it capability so try delete some applications that you downloaded your self to free the memory space on your phone.
cheers
5/29/2010 8:22:28 PM •
LG C1500...
Answered
on May 29, 2010
Changing phones to anoher carrier
This can not be done because both networks use different technology. One is GSM the other is CDMA. Frequency to transmit radio signals are entirely different.
br,
www.phonefreedomjamaica.net
5/13/2010 4:10:04 PM •
LG C1500...
Answered
on May 13, 2010
My phone is stuck on headset
I would try a to reset by pulling the battery out then putting it back in.Leave it out for about 30 seconds.
4/18/2010 5:20:31 AM •
LG C1500...
Answered
on Apr 18, 2010
