20 Most Recent Whirlpool GT4185SK Microwave Oven Questions & Answers
2answers
My microwave would not turn off. Door closed and light/turntable off, the microwave continues to work when not selected on.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at [email protected] with your name, address, phone number and the model & serial numbers of the Microwave.
11/6/2019 7:30:22 PM • Whirlpool... • Answered on Nov 06, 2019
How to open control panel
Remove the top cover by removing the screws on the sides and back.Now once the top cover is removed , you can see that the front panel is slide into the front chassis , remove the screws and push the panel slowly, remove all the connection to the board after tagging .
2/12/2013 12:19:03 PM • Whirlpool... • Answered on Feb 12, 2013
Whirlpool GT4185SKB-1 Built in Microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
9/11/2011 10:09:39 PM • Whirlpool... • Answered on Sep 11, 2011
0answers
Microwave when heating sparks and
heatman101
5/8/2011 3:53:08 AM • Whirlpool... • Answered on May 08, 2011
Microwave Not Working
Basic Microwave Oven TroubleshootingTips
heatman101
3/27/2011 6:09:05 PM • Whirlpool... • Answered on Mar 27, 2011
Everything works in it, EXCEPT IT IS NOT HEATING
heatman101[]]\
3/27/2011 6:05:52 PM • Whirlpool... • Answered on Mar 27, 2011
My husband put a bowl of soup in our microwave and
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
2/25/2011 3:39:07 PM • Whirlpool... • Answered on Feb 25, 2011
Microwave stopped cooking. Fan works , but sounds
heatman101
10/26/2010 3:05:16 AM • Whirlpool... • Answered on Oct 26, 2010
The microwave is on and turntable is turning but
heatman101
10/12/2010 2:51:47 AM • Whirlpool... • Answered on Oct 12, 2010
My whirlpool gold microwave does not heat. It goes
heatman101
utui
9/30/2010 5:06:49 PM • Whirlpool... • Answered on Sep 30, 2010
Doesnt heat food
heatman101
ss
9/30/2010 2:16:04 PM • Whirlpool... • Answered on Sep 30, 2010
2answers
I own a Whirlpool gold
Hi. this is a possible heating device malfunction. You may be able to reset the main controls in this case. I recommend to unplug, or shut-down the appropriate circuit breaker for 3 minutes. This will drain all power, and possibly reset the board. This may fix the issue if the damage is not severe.
Now, if after the 3 minute reset, the unit continues to not heat, this will confirm that the main heating device(magnetron),has failed. It is possible that the cut-off fuse has failed. If this is the case, simply replace the fuse. If the fuse continues to show continuity, replace the magnetron.
7/8/2010 5:06:27 PM • Whirlpool... • Answered on Jul 08, 2010
Panel won't respond
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your model number).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
On some models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. "Ed" Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
5/28/2010 2:17:44 PM • Whirlpool... • Answered on May 28, 2010
Getting sparks when in use Whirlpool GT4185SKB
If your microwave has a turntable its probably just burnt food inside or above the oven chamber that has carbonized. If it doesn't have a turntable its possible the stirrer above the oven chamber is stuck and not moving the microwaves around, therefore causing over heating and arcing. It also could be that the stirrer blades are hitting inside. Hope this helps
2/21/2010 2:30:07 AM • Whirlpool... • Answered on Feb 21, 2010
Whirlpool GT4185SK Microwave Oven Logo
46 questions posted
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Microwave Ovens
Most Popular Question
husband put bowl soup in our microwave
  • Microwave Ovens
