20 Most Recent
Samsung SGH-A800 Cellular Phone Questions & Answers
How to delete all phone
hi :)
for samsung ,u can key *2767*2878# or *2767*3855#
the both code as above use for format samsung mobile phone.
if my solution useful,please rank me.thank.
I DO NOT KNOW HOW TO ULOCK THE PUK CODE
if your phone is asking for puk code then ring your operator and they will give you the code for free over the phone thats the only way of getting puk code as its different for every service provider but they will provide code for free so give them a call you can also get it off their website sometimes so have a look call them they give you code
Unlock code for a800
Dear Brother:ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
Sgh-a800 shows no display even
If the display went out then the optical cable probably became frayed. If this is the case then a technician might be able to fix it but generally it will be cheaper just to get a brand new phone.
User Guide
You can find your user guide at this link:
http://tiny.cc/VuKWW (This mauual is in PDF Format and may take a minute -or two- to load)
If you need a PDF Reader to view this manual, you can download Adobe Reader free here:
http://get.adobe.com/reader/If this information was helpful, please give me a big thumbs-up when you rate my answer. Thanks!
I need unlock code
1. Take the SIM-card out. It's important that the SIM card IS NOT in the phone, during the following steps!!
2. Turn on your phone without the SIM-card
3. Enter *2767*637#
4. Insert the new SIM-card, and see if it is unlocked
I need an unlock code for a samsung cell phone?
Call you service provider. They have the unlock code for your phone. If they ask for a reason, I would tell them that you will be travelling over seas and will be using a pre-paid SIM card in the country that you are "travelling" to. They will have an unlock code for you within 3 days or so. Otherwise, you can type in your model number along with the word "unlock code" into google and there are many websites that provide phone unlocks, for a fee. Hope this helps.
Display
u can get it from samsung service center
Network locked
try this without sim card in the phone *2767*637# if it dont work with no sim in the phone try it with the sim in failing this if it stll dont work then the code has been tryed to many times and can only be unlocked using a cable ok
Phone has been idle for a few months. Will not turn on or charge.
Hi have you tried to charge the phone What hapens ?
1. could be that the charger is not outputing the proper current an longer may need to purchase a new charger for the Cell Phone.
2 try to charge the battery in a different phone if possible maybe a friend has the same brand otherwise only one option left buy a new battery and chage it if it works then problem is fairly simmple
the old battery has reached the end of its life and will not charge !
PUK
it will ask for the PUK code when you try inserting the wrong pin
for 3 times ...
so to get the PUK code follow these steps:
1. call to your network provider s customer care from some of your friends number of the same network ...
tell your number & ask them for the PUK code..
2. they may ask you the details of sim like in whose name it is etc..
answer that ...
3. after that they will provide you the PUK code note it down
4. enter the noted PUK number to your cell ...
5. your sim will get unlocked ....
caution:
if you try inserting the wrong PUK codes for more than 5 or 10 times it
will completely block the sim after that you must contact the network
provider s shoppe only to get it unlocked ..
remember this ...
this
solves your problem ...
any doubts you can reply me
i am always here to assist you
thank you
bye
please rate my solution
How do I send a text message?
open the phone, press yes(left side), scroll down to `new message`, press yes again, type in you text message, it may be on predictive text, to remove predictine text press `no` (abc mode)and then press `yes`, to send the text press `yes`
scroll down to send, press `yes`, type in the phone number of the reciepiant, press `yes`
if the phone number is saved in the phone instead of typiny it in press `yes` and scroll down to the number press `yes` and press `yes` again ... job done??
TM PUK CODE
ask your service provider, they will give you the code PUK.best of luck!
