20 Most Recent
Motorola Mobility E770 Cellular Phone Questions & Answers
My phone is motorola e770.
You'll just need to reset your phone and if this happens again contact the Motorola technical team department.
8/7/2017 7:49:03 PM •
Motorola...
Answered
on Aug 07, 2017
Memory Card dnt work ? how do i fix it ?
hi..there may be a problem with your mobile phone micro-sd slot
or their might be a problem with ur micro-sd card. u can also do
one thing just take the micro-sd card and clean the pins of micro-sd
card with spirit,aftershave lotion, isopropyl or body spray. just take
the above mention chemical in a soft cotton cloth and then try to
clean the pin of sd card by rubbing the cloth on it.
try this out..
thank u..
rate me..
1/24/2016 11:08:19 PM •
Motorola...
Answered
on Jan 24, 2016
My E770 will not turn on. The key pad lights up
Your mobile's software has been corrupt. you need to flash repairing your software. goto your mobile's service center or at any software repairing shop and ask them for software repairing.
2/2/2011 4:48:07 AM •
Motorola...
Answered
on Feb 02, 2011
I forgot my pasword for getting into my motoroloa
Since
your phone is locked, it means you need to unlock the phone to be able
to use it again. It is certain that you cannot unlock this phone for
free, anywhere or on any site.
Though there are some Samsung phones
that can be unlock for free, but unfortunately, yours cannot be
unlocked for free because it is a new model phone.
Some sites
offer to unlock phones and charge some amount of money, but I won't
recommend that for you because those unlock codes are not reliable.
I
would advice that you take the phone to a phone tech within your
area/vicinity, and your phone will be unlocked there within a couple of
minutes. The phone code will be reset with with computer using a phone
cable. I'm sure you do not have the facilities to unlock your phone
that's why I'm referring you to a phone tech.
But if you want to
unlock your phone online, you can visit this
link:http://mobileunlocked.com/index.php or
http://www.unlockadvantage.com/index.php or http://www.mobile-unlocker.com/
Good luck.
1/1/2011 10:23:06 AM •
Motorola...
Answered
on Jan 01, 2011
E770 didnt read my memory
you can insert the memory card correctly and check it. then also it will not work then you can switch off the phone then inseart the card and then switch on, it will work
9/15/2010 8:30:29 AM •
Motorola...
Answered
on Sep 15, 2010
Unlock my phone
Dear sir, How are you, I'm sending you some codes and I hope these codes will surely help you out.:)
Nokia Code & their function:
- *3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
- #3370# Deactivate Enhanced Full Rate Codec (EFR)
- *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
- *#4720# With this Nokia code you can deactivate the Half Rate Codec
- *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
- *#9999# Phones software version if *#0000# does not work
- *#06# For checking the International Mobile Equipment Identity (IMEI Number)
- #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
- #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
- #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
- #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
- *#147# This lets you know who called you last (Only vodofone)
- *#1471# Last call (Only vodofone)
- *#21# This phone code allows you to check the number that "All Calls" are diverted to
- *#2640# Displays phone security code in use
- *#30# Lets you see the private number
- *#43# Allows you to check the "Call Waiting" status of your cell phone.
- *#61# Allows you to check the number that "On No Reply" calls are diverted to
- *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
- *#67# Allows you to check the number that "On Busy Calls" are diverted to
- *#67705646# Phone code that removes operator logo on 3310 & 3330
- *#73# Reset phone timers and game scores
- *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
- *#7760# Manufactures code
- *#7780# Restore factory settings
- *#8110# Software version for the nokia 8110
- *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
- *#94870345123456789# Deactivate the PWM-Mem
- **21*number# Turn on "All Calls" diverting to the phone number entered
- **61*number# Turn on "No Reply" diverting to the phone number entered
- **67*number# Turn on "On Busy" diverting to the phone number entered
Good Luck. :)
12/16/2009 11:22:59 PM •
Motorola...
Answered
on Dec 16, 2009
Housing for v8??
buy a parts phone on ebay or one of the estores on ebay may have one
8/1/2009 6:22:33 AM •
Motorola...
Answered
on Aug 01, 2009
