20 Most Recent Soyo DYLM1986 Monitor Questions & Answers
0answers
0answers
0answers
0answers
My soyo monitor worked for
Look for bad caps with domed tops first, then post back what you find inside.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
2/2/2011 1:27:18 AM • Soyo DYLM1986... • Answered on Feb 02, 2011
Does this monitor have speakers
no it does not have speakers sorry
1/21/2011 8:07:30 PM • Soyo DYLM1986... • Answered on Jan 21, 2011
Led on front of monitor is blinking. will not
In most cases it means that there is no video feeding in. Have you checked the cables to be sure they are all secure?? have you tried another monitor?(if you can) also maybe check the cable itself as it can be the problem(you can get a new one for $1or so)
9/25/2010 3:57:22 PM • Soyo DYLM1986... • Answered on Sep 25, 2010
Screen goes into hibernation mode and does not
Does it do the same if you hook this monitor up to another PC? It can be in the PC setting. Need to narrow down the problem before trying to open up the PC or the monitor for repair. Post back so we can figure out further.
4/1/2010 2:51:15 AM • Soyo DYLM1986... • Answered on Apr 01, 2010
My Soyo DYLM1986 won't come on and is clicking
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
3/31/2010 10:19:10 PM • Soyo DYLM1986... • Answered on Mar 31, 2010
When i power on it dispalys a white screen and it
It can be caused by bad caps in the power supply, bad inverter circuits, or bad lamps. Look for bad caps with bulging top first, post back what you see so we can help you more, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
3/5/2010 5:12:44 PM • Soyo DYLM1986... • Answered on Mar 05, 2010
When we turn the monitor on we get a white screen
pls dont change the monitor while using..... bcas its an electronic good.... so pl turn off it and turn what ever you want
2/25/2010 8:54:29 AM • Soyo DYLM1986... • Answered on Feb 25, 2010
Screen won't come on, and it is clicking inside
unplug everything from the computer then reconnect everything help?
2/6/2010 2:33:24 AM • Soyo DYLM1986... • Answered on Feb 06, 2010
Power Supply Card crashed. Where i can I buy this
Does the PC light light up or does the PC make any kind of sounds at all? If not, it's probably the power supply. Power supplies are not cards though. You can get them about anywhere that carries PC hardware. Be sure you get a power supply that is suitable to the needs of your system.
1/1/2010 7:17:51 PM • Soyo DYLM1986... • Answered on Jan 01, 2010
Anyone have a url for the drivers for winxp? for the soyo dylm1
I have this monitor and it does not need drivers.
If your graphics card supports it use the DVI connection as this gives a better display and the card will normally suggest your best resolution for you.
If you are using the VGA connection you may have to play around a little to find the best resolution that suits you.
If you get an OUT OF RANGE message you are trying to run the monitor at a resolution that it cannot handle and should drop it back down a little.
Normally 1280 x 1024 is pretty good for most people.
Hope this was of use.
10/4/2009 2:45:25 AM • Soyo DYLM1986... • Answered on Oct 04, 2009
Turns on and off
Double check all cables and connections, make sure they're tight.
Could be the power supply, video card, or the monitor may need replacing.
Hope this helps
Thanks
9/11/2009 3:26:48 AM • Soyo DYLM1986... • Answered on Sep 11, 2009
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
3/6/2009 12:23:50 PM • Soyo DYLM1986... • Answered on Mar 06, 2009
2answers
Monitor no power
Check Internal Fuse on Power supply board
2/10/2009 12:53:06 AM • Soyo DYLM1986... • Answered on Feb 10, 2009
2answers
Unable to reset settings on Soyo Pearl MT-NI-DYLM22E6 DVI Widescreen
Your monitor is failing due to age.
10/19/2021 4:02:03 AM • Soyo Computers &... • Answered on Oct 19, 2021
Soyo DYLM1986 Monitor Logo
Popular Tags
25 questions posted
Top Soyo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Soyo Computers & Internet
Most Popular Question
when power dispalys white screen
  • Computers & Internet
