20 Most Recent
Philips 37PF5321 37 in. HD-Ready LCD Television Questions & Answers
Menu button stuck?
Sometimes you can get to the side of the button with a straight pin(unplug t.v. 1st) and get in and work with it til it pops out again. If that doesn't work, try some contact glue that will rub off when dry and glue a toothpick to it and try to wiggle it out that way. Other than that, you or a qualified repair technician would need to pull the back off to release it. Good Luck
I have a philips 37" flat screen TV, when I switch
hi,
There is problem with the back light of your tv. In LCD tvs CCFL are used as back light to give light to independant pixels. CCLF lamps required high voltage to light. This high voltage is provided by the inverter board inside ths tv. If any one of the chopper transformer (high voltage transformer) have some problem then the inverter will shuts off itself preventing damges to the power supply.
You have to check the 24V from the power supply. If its ok the you have to check the inverter board.if avilabe replace the same. if you are not able to do the same i will prefer to consult some one experienced in it. Back light inverter board will look like one in the picture.
ok
No picture problem on Philips Flat TV 37PF5321 37
I am suffering from the same problem. When I turn on I get sound but no picture, although I do get the backlight coming on when I turn it on, I then get about 1/2 a second of picture then nothing. Even if I select TV specific functions such as the menu, I get no menu screen come up.
Any ideas out there?
The screen of my LCD 37PF5321 is broken and no
if you hurry you can order one off ebay its a olevia but they use the same screen 220724844497 which is an lg philips panel. Before doing that check if your backlight inverter is defective. A more common problem with this tv is blue screen from tcon board failure which is quite easy to fix.
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
