20 Most Recent
HP PhotoSmart C4280 Laser Printer Questions & Answers
We refilled the color ink cartridge and now it
newer cartridges often have chips which tell the printer if the cartridge is empty. these chips have to be reseted (sorry, don't know how at the moment - websearch should help). did you try a genuine cartridge? if not, you should try this first. i think the problem is a chip issue. if it's not a chip issue, the refill-ink could have damaged the printer head. but as far as i know hp integrates the printer heads in the ink cartridges -> new and genuine cartridge should help
When I try to line
Have/had the same problem: Getting "paper size mismatch" on the C4280 status
screen, after we got a paper jam. Every time we hit OK and put in paper,
Message about "Now printing Alignment page", it feeds through quickly, with
nothing printed on the page and reverts back to Paper size mismatch. Finally
got rid of the error, not sure how, but now when I try to copy anything, we only
get the lower right postion of the document that I'm trying to copy. Printing
from the PC seems ok.
Powered off and back on, and it is back to P"now
printing alignment page, quick feed through and "paper size mismatch" error.
AND
When copying directly from the glass panel,it will only print a quarter of
the page -however it prints and coorectly if we print directly from the
computer.
The problem is the paper size sensors. Remove the plastic access panel that
is for access to the rollers in the back and has 4 rollers on it. There are two
papaer sensors attached to the printer circuit board (PCB). The control arm for
the sensor is a small plastic piece that extends slightly into the paper path
above the PCB. The plastic can be broken when you are removing a paper jam. I
stuck a small piece of a match stick in the sensor to keep it open (as though a
wider piece of paper was passing throught the printer). I can't switch to
smaller card stock, etc, but who cares, it works.
The copying problem is caused because the C4280 will not scan correctly until
after it does the alignment phase.
My printer is printing things
Each and every printer brand has it's own software for calibration. Access your application for maintaining the printer and re-calibrate it. If this won't solve your problem then consider yourself buying a new printer head.
Hope this works for you.
I have a HP Photosmart
Hello Sherryjean,
I know how frustrating this issue is.
I request to perform the steps provided in the following Hp web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01124255&cc=us&lc=en&dlc=en&product=3192753&tmp_track_link=ot_search
If the issue persists even after performing the above steps, please try with different type of paper. If the issue persists, then it will be a hardware failure and please contact the nearest Authorized Service Provider to repair this unit.
I hope the above will resolve the issue.
Note: HP PhotoSmart C4280 all in one is not a Laser Printer but a ink jet printer. :)
Regards,
Tony
I keep getting the "paper
Hello
Try to unplug the power all, and make hard reset. check inside the printer might have small paper inside and clean you printer.
thnaks
