20 Most Recent
Chevrolet 1996 Chevrolet Blazer S10/jimmy S15 Radio Questions & Answers
Radio is on but has no sound
the speakers might not be working,i would first check to make sure they are good and check the wiring to the speakers
Which fuse controls the rear hatch on my 1996 Chevrolet s10 blazer?
open the driver side door on the side of the dashboard there's a fuse boxthe same to use the works your power locks is the same one for ur rear but the best thing you can do is just look at your trucks manual if you have it it'if you don't have it look on Googleit will show you what number fuse it is
Steven its a 99 s 10 no power at the fuse ?
im moved you.
to S10
no power mean the voltmeter is not 12v>???????
the fuse has 2 ends, no power to me means both ends, right.>?
what fuse box, cab or bay?
that means the power ;means the fuse in cab is dead because the
MAIN fuse in the BAY is blown.
just like you home there are main fuses then sub branch fuses.
then the battery, its dead, all is dead.
1 step at time use the voltmeter and walk backwards to battery
and find the OPEN circuit. whomever it is. (chips fall where the may)
as will TRUE cause.
Trans gets stuck where it only has 2nd 3rd no od or 1rst gear
Do you have a code reader? If there is a message informing you that the transmission is in limp mode. You should be able to retrieve engine codes. From your symptoms I think that you either have an issue with fluid flow (clogged filter and/or screens), worn pump, low trani fluid level, trani fluid temp, possibly a correlation problem with the speed sensors, clogged air filter, dirty MAF sensor, clogged fuel filter, or blockage in the exhaust system. It will only be through diagnostics that these suggestions can be crossed out and narrowed down. Please let me know if that helps or if I can be of any more assistance, good luck.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
