20 Most Recent
Chevrolet 1995 Chevrolet Blazer S10/jimmy S15 Radio Questions & Answers
My 1995 chey blazer 4.3 keep blowing the 20amp fuse that control the horn, inside dome lites, cigarette liter and rear hatch release
You may have a short to ground meaning your wires are pinched together or you have the lead to one or more of yor devices touching metal. Thats two options the other one is one of your devices may be bad and hopefully this is the case. To test that theroy you will need to have several spare fuses. Start by unplugging one device at a time them inserting a new fuse and keep doing this process until the fuse doesnt blow then you wil have your culpret. If that doesnt work you will need an electrical specialist to track down which part of your wiring is shorting your fuse out. I would try your cigarette lighter and horn first.
How do you remove passenger door panel on 1995 chevy blazer
the grab handel has 2 bolts that need removed i belive they are 5/16 as for the rest of the panel slip a flat bar behind between the door and panel and pry gentle as not 2 break the door panel it is held on by push pins that you can buy at your auto parts store its sounds harded than it is
