20 Most Recent
Syntax Olevia 527-S11 Television Questions & Answers
The tuner's not working
no channels? blue screen? no signal?
Solution:
A Converter hdtv box... is the SOLUTION!!! try it..youll see!!!
I had the same scan-turner problem with my Olevia "digital" Olevia tv!!
Because I was curious i tried that to see what happen..and it worked!!
Olevia tv fixed!!!
Easy..your tv is not able to scan cahnnels...then, the solution is to plugging "a thing" that can do that: a converter box.
Olevia 527-S11 Power Board
you can try shopjimmy.com, or ebay. You will want to search for the part # DPS-162CP. Verify that this part# matches your old one
I have vertical lines on the entire right side of
most of the stuff from jimmy's its second hand ( not good working or working maybe) first and the last i suppose you got a problem with the power supply on the T con on the second i suppose you have a problem with the big chip in the middle the scalier :D
We are having problems getting channel 3 on our
I cannot locate free user manual for your TV, what you need to do is to go into the TV Tuner setup menu and have the TV rescan for the TV signal, it should pick up the Ch3 or Ch4 signal from the Dish box (depend on what the Dish box RF output is set to 3 or 4).
I myself will not use the RF output of the Dish box, I would have use the Composite video out (Yellow RCA jack) or Component video output of the Dish box to get the best pictures which the Dish people should have recommend you to do, the Video out put of the Dish box will feed the AV1, AV2, Component 1, 2 depend which you have available. You should also be able to punch CH3 or 4 on the remote control for direct access.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
I have cable tv hooked
this might have to do with your wire connections. Its either the wire used for the connection is bad or you did not connect it properly.
To verify, test the TV with another connection wire or connect the TV to a DVD player.
You can also try other connection method like, HDMI and Component connection.
Take care.
