20 Most Recent
Motorola Mobility V3x Razr GSM World Cell Phone (Unlocked) Headset Questions & Answers
Unlock
please can you tell me how to ulock my motorola V3.
5/6/2011 10:55:39 AM •
Motorola...
Answered
on May 06, 2011
How to remove a gprs settings (web sessions)
just clear the browser history ...if they were web based sessions it will remove themselves with the rest of teh pages..or if you want to remove them one by on e...check the history ...highlight them one by one ...and on the options select delete
1/15/2011 9:31:11 AM •
Motorola...
Answered
on Jan 15, 2011
Free unlocking or subsidy code for mobile phones
NO. But I can forward you onto someone that may be able to help. This does does come at a minimal cost. To my knowledge there are NO unlock sequences for subsidy passwords. I know this as a fact
9/27/2010 12:45:24 PM •
Motorola...
Answered
on Sep 27, 2010
How to change the usb port on a motorola razr v3 phone?
this is for advanced users only, you have to realize that if you havent mastered disasembly of a phone trying to alter the pcb board is a bad idea. the usb port is held on with a clear epoxy resin. Removal requires a scalpel and a heat gun. you will need to have new epoxy to put the new usb port on, keep in mind that there are 6 to 8 pins on mini usb ports. It is impossible to solder it on. use a pry tool to pull away the backing on the phone, remove the black rubber studs and pull the pcb board away from the backing (being carefull of the two snap clips holding the whole housing together. Flip the pcb board over and the usb port is exposed! hope this works out for you. its very difficult to do by hand!
6/7/2009 12:07:45 AM •
Motorola...
Answered
on Jun 07, 2009
Unlock razor
how do i unlock a razor from CINGULAR TO T-MOBILE????
1/9/2009 5:12:54 PM •
Motorola...
Answered
on Jan 09, 2009
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
10 hours ago
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
