20 Most Recent
Razer Tarantula RZ03-00070100-R2U1 Questions & Answers
I have a Razer Tarantula
Some programs like Skype set up their own profile in the audio hardware side of the operating system. Check the audio properties and see if two or more are listed and change to the other one and check the operation.
My media player keys on razer tarantula keyboard
after i checked the preferences in winamp i found out my hotkeys were not enabled so thats why they were not working. So if you have the same problem go to preferences -Global hotkeys and check the 2nd box
Keyboard keeps highlighting everything makes it
I would check your Shift keys and see if they are sticking. Try pulling up on them. If you determine that they are the problem, you might need to disassemble the keyboard and clean the keys. Good luck!
Tarantula doesn work after installing new firmware
there seems to be alot of firmware issues with alot of razors products at the moment, use another keyboard for the minute and navigate to their site, downgrade your firmware to the one that worked. or alternatively restore your computer to a restore date that occured before you installed the new firmware/drivers.
hope this helps
kev
O button doesn't work properly
Well i started having the problem with the letter 'B' so what i did was i took the key out and i placed a small square bit of tissue paper under the key now it works fine....... although this shouldnt happen with such an expensive keyboard. Im never buying a razer product again.
I can't install Tarantula rz03 on my pc neither its driver software!
You must enable USB Keyboard in your BIOS.. and Turn OFF PS/2 detect if it has it. Have a look in the BIOS and see if there is any entries for USB etc...
What you need to do is, boot up & then install the correct "Drivers" for your Keyboard from the CD etc that came with ya KB, then reboot and after reboot insert ya keyboard.. if it asks for drivers point it to them, on CD etc. THEN after next and subsequent boots it should be OK.
I had a squiz on "Google' but didn't find any drivers? :(
Keyboard Razer Tarantula doesn't work
i tried to install the same keyboard and im having the exactly the same problem. i had a saitek eclipse before and it worked perfect. but now nither works and i uninstalled my mouse on accident as well so now im totally screwed
Laptop keyboard problem
check to see if the "Fn" button is stuck down, it sounds like the keystrokes you are describing are some shortcut keys to provide adjusting functions for the laptop facilities. Turn off the laptop, disconnect the power adaptor, disconnect mouse etc... and pick up the laptop and give it a gentle tap from behind the machine, and also go through all of the keys and try to press them and you may find one or more are stuck down (in particular the Fn key or similar).
Mouse Wheel not working
with mouse controls so cheap and so readily available , why would you bother with cleaning/ pulling it apart
is it wireless mouse ( battery flat) usb mouse ( cable problem) or mouse driver ( stopped working)
