20 Most Recent Peavey HEADLINER-HEAD 600W Bass Guitar Amplifier Head - Questions & Answers
How can i get the circuit diagram of this product?
Jose, you may want to try Peavy support link below and make circuit diagram inquirery. The manual has a diagram, but not much. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." http://www.americanmusical.com/ItemFiles/Manual/PEV_HDLNR1000_manual.pdf Peavey Headliner Bass Amp Packs Power Features in Lightweight Head Peavey Headliner Operating Manual
5/3/2016 8:20:01 PM • Peavey... • Answered on May 03, 2016
Sanpera 1 with Peavey Viper 1 amp - no longer looping
If your Sanpera 1 pedal has suddenly stopped looping on your Peavey Viper 1 amp, it's possible that there's a hardware or internal issue. It's recommended to contact Peavey customer support or a professional technician to diagnose and resolve the problem.
11/5/2023 3:21:13 PM • Peavey Audio... • Answered on Nov 05, 2023
Is there a crossover in the peavey kb 300 the one with the xlr on the front
You mean the KB A300 if it has a Mic input with XLR. No, there is no crossover in it as there is only one 15" speaker and it doesn't need it.
3/12/2023 5:23:49 PM • Peavey Audio... • Answered on Mar 12, 2023
2answers
I have a peavey tnt 115 bass amp and I need to replace the amplifier output transistors, where I could buy them all the new set
Sorry we have no parts here or any way to locate them.
8/2/2022 1:05:13 AM • Peavey Audio... • Answered on Aug 02, 2022
I have no power to my PV10 mixer. It was going fine a few days ago now nothing. Power cord is good and power at wall is good.
The Peavey PV-10 is an unpowered mixer. Simply bypass it with a signal source to troubleshoot its operation. The problem is elsewhere.
2/18/2019 9:13:04 PM • Peavey Audio... • Answered on Feb 18, 2019
I replaced the equalizer circuit board on my Peavey Tour TKO 115. Now I have no power. Any thoughts?
You might have disturbed a connector that feeds power, making it come loose. Turn the unit off unplug it from the mains and recheck all connections on ALL the boards, not just the one you replaced.
6/3/2018 12:15:57 AM • Peavey Audio... • Answered on Jun 03, 2018
I want to no wat this parts number is Q4025p for a peavey cs 800
2 Channel Peavey CS-800 Amp (800 Watts) ... Peavey CS-800x 800 Watt PA Stereo power Amplifier. The Part in question Q4025P is an alternistor. Two SCRs back to back that may have shorted out if it is not working.
5/14/2018 9:44:13 PM • Peavey Audio... • Answered on May 14, 2018
Peavey cs400. Plays very low thru speakers and makes humming sound
Either there is a bad ground or the power supply has blown a diode or capacitor.
1/23/2018 1:41:02 AM • Peavey Audio... • Answered on Jan 23, 2018
0answers
2answers
High pitched squeal from powerd speakers
Check to make sure the WIDEST blade of the AC power plug is actually the GROUND (as in "not HOT") in the new location!
4/30/2017 4:35:52 AM • Peavey Audio... • Answered on Apr 30, 2017
I have an old Peavey Transfex Pro 212s that spent several years in storage. It's had the battery-less modification. The unit powers on fine but will not output sound past the preamp.
I am thinking what if the power amp has a separate power supply to the pre-amp. If it does then something in that is causing the problem. If it doesn't then it's something on the power amp board. Perhaps a voltage regulator. If the power amp is a single IC job replace it. Another possible cause is if the volume control is done via a single IC. If that has gone it would cause the strange things that are happening. One thing is certain it's something that both channels pass through the device that is faulty or it effects both channels.
12/2/2016 6:31:29 PM • Peavey Audio... • Answered on Dec 02, 2016
Power Supply Peavey src2400
So, what is your question, my friend ? Peace
10/10/2016 8:41:03 PM • Peavey Audio... • Answered on Oct 10, 2016
How do I troubleshoot this mic?
Check the coil resistance, first on the capsule (unscrew the front screen) and then on the No. 2 and 3 pins on the XLR. Now you know.... Probably your membrane coil went away. That happens, so sorry, but check... Peace-
7/18/2016 9:05:21 PM • Peavey Audio... • Answered on Jul 18, 2016
The name of : vr104?
Variable potentiometer.
6/22/2016 2:38:20 PM • Peavey Audio... • Answered on Jun 22, 2016
Muddy sound
Turn down the lows and bring up the highs
4/13/2016 1:26:47 AM • Peavey Audio... • Answered on Apr 13, 2016
Can i use a peavey PVi2 mic on my peavey renown 400?
No you need a preamp for the microphone found on audio mixers. You will not get good sound from it even if you do buy a mini mixer to provide a preamp for the mic. I would suggest a pa like the ones in this link. Most of them have built in mixers (with preamps) also. Portable PA Systems Sweetwater com
4/13/2016 1:25:38 AM • Peavey Audio... • Answered on Apr 13, 2016
Peavey HEADLINER-HEAD 600W Bass Guitar Amplifier Head - Logo
1 questions posted
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Peavey Audio Players & Recorders
Most Popular Question
get circuit diagram product
  • Audio Players & Recorders
