20 Most Recent
Philips DVDR3435V/37 DVD Recorder/VCR Questions & Answers
The VCR shuts off after
There is a part that is called an idler wheel assembly that is critical for play, rewind, and fast forward, and may have stopped working. The second possibility is that the drive belt that runs the idler assembly has broken or come off.
1/1/2011 6:59:59 PM •
Philips...
Answered
on Jan 01, 2011
Philips dvp3150v vcr/dvd combo
try following codes
RCA universal remote controller:
021, 022, 062, 096, 124(VCR)
162, 356, 357(DVD)
Philips Magnavox Universal Remote PM335
130 226 330 536 631 734 738(VCR)
441 442 943(DVD)
many direct codes doesn't work ,code searching method all ways work better but irritating
STEPS:
1. Press and hold CODE SEARCH
until the INDICATOR LIGHT
lights, then release CODE
SEARCH.
2. Press and release the device
button for the device’s code
you are retrieving (TV,VCR or
DBS•CABLE). The INDICATOR
LIGHT will blink once then
remain lit.
Note: For AUX, press DVD•AUX
then the device button for the
code you are retrieving.
3. Press and release CODE
SEARCH. The INDICATOR
LIGHT will turn off.
4. Starting with 0 on the keypad,
press the number buttons in
order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the
INDICATOR LIGHT to blink is
the first digit of your code.
6. Repeat step 4 until you have
retrieved all three numbers in code
NOTE:
if any of the above works note down code used in small bit of paper and place it in the battery chamber(safe place)
6/14/2010 3:05:52 AM •
Philips...
Answered
on Jun 14, 2010
When trying to set up
E2 Is a code indicating that the tape chassis is locked in the eject position. You may want to have a look at the mechanism to be sure nothing has been bent or jammed - it should move freely when a tape is inserted.
The error codes for the Mitsubishi VCR's are as follows:
E1 - Loading motor lock in the load direction.
E2 - Loading motor lock in the unload direction.
E3 - Drum motor lock.
E4 - Reel lock detection.
E5 - Video envelope detection.
To reset error message - It will be done automatically after repaired or press VCR power switch for more than 8 seconds.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
4/22/2010 8:06:43 PM •
Philips...
Answered
on Apr 22, 2010
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
1/27/2009 6:00:09 PM •
Philips...
Answered
on Jan 27, 2009
I found a loose part in the VCR bay I'd like to reinstall. Part #T5B
I found that part #T5B was on the bottom of the VCR tape tray on the right side of the VCR tape bay opening and was spring activated by inserting the tape to allow the tray to retract into the player mechanism. Without a tape installed, part T5B prevents the tape carriage from retracting.
However, I still couldn't get the whole mechanism timed properly, and gears were skipping teeth, the mechanism was still binding, and shutting the power for the whole player down. Therefore, I removed the rubber drive belt that operated the VCR tray insertion/ retraction process, and disabled the VCR side from operating at all. This allowed the power to remain on and allow the DVD side to work properly.
This worked only for the Phillips DVP3150V/37. I cannot say for certain if other Phillips players are the same.
10/14/2008 12:45:52 AM •
Philips...
Answered
on Oct 14, 2008
VCR won't record at a set time
Check that the clock on the machine is set to the correct time and date. Check am/pm.
This problem is usually caused by incorrect time & date.
4/2/2008 10:10:32 PM •
Philips...
Answered
on Apr 02, 2008
Is there a way
Not really, these VCR tapes that are copyrighted from the store are highly secured. So you can not dub them actually.
11/18/2007 3:38:42 PM •
Philips...
Answered
on Nov 18, 2007
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM •
Philips...
Answered
on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay
https://www.ebay.ca > ... > Remote Controls
Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ...
$67.67 · In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay
PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost.
US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com
https://www.replacementremotes.com > philips > buy-...
PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM •
Philips...
Answered
on Dec 05, 2023
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM •
Philips...
Answered
on Oct 31, 2023
