20 Most Recent
Skull Candy Skullcrushers Headset Questions & Answers
Bass speaker buzzing
I've had this problem too multiple times. Usually when it happens, the battery dies soon after, and once I replace the battery, the buzzing goes away. If you are having the same problem as me, try putting a fresh battery in :)
Rattling
check the coils sound like they are burned up or blown
Dont work when i put them into headphone slot. i
It is broken wire(s) inside the cord at the plug. The is either get a new jack at Radio Shack or similar and solder the wiers to the contacts as follows bare copper (2 of them) to the "sleeve" which is the part of the plug closest to the cord, then solder each of the other two wires to one of the other contacts.
Only the right side of the headphone works and the
yea i have the exactly same problem exept on my left??? did u find a way to fix them? i open'd them up and all the four wires were welded to the appropriate port. i think its in the wiring.... :( this is just very sad stuff with such beautiful head phones
The bass is very distorted
you may have blown a speaker. check the wires behind the speaker to see if there is a short(two or more bare wires that touch)
I have a pair of Skull Candy and my grand daughter
You can remove the plastic around the cut ends and tie the corresponding wires back together and then cover the visible wires with electrical tape. This may or may not work if you're not experienced but if you're willing to give it a shot, good luck.
