20 Most Recent
Casio Ctk-510 Full Size 61 Key-16 Note Polyphonic Keyboard Questions & Answers
No sound on my casio mz-2000
Please first make sure that the volume is turned up and that there is no earphones connected to the piano. Because either of these things could lead to the issue that you're describing. If these actions don't work, please refer to the troubleshooting section of your device's manual for more procedures.
Thank you.
I have the casio px130
there is a special kind of tape that you use try going to the music store and ask for it
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
