20 Most Recent
Case Logic WIRELESS CLBTH-10BLK BLUETOOTH HEADSET Wireless Headset Questions & Answers
How do you operate bluetooth CL-BT001-BK
Scanned manual available but is too large to load here. Basically, all functions are handled by the phone, the headset's only control is the on and off switch.
The 3mm jack on the
There are two wires.
no matter which way they are connected, they will produce sound.
There will be one way, however, that the sound will be better.
Trial and error will tell you which is the right way, and then you can twist the wires together and tape it, or solder it for a more professional look and seal it using shrink hose.
Hope this helps!
No driver
Headsets usually doesn't need drivers
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
15 hours ago
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
