20 Most Recent
Intel Celeron D 325 2.53GHz 533MHz 256KB Socket 478 CPU (Bulk) Questions & Answers
What is the hidhest ram i can use on a celeron 2.6
Hi. The amount of memory that can be installed is limited by the motherboard, not the CPU. That being said, the motherboard you have listed will take the following memory:
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.
IN MY PC THERE IS
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
What mem can I upgrade to in a celeron 2.53 which
well it doesn't matter what cpu (celeron 2.53) the computer has, it all depends on the mainboard of the computer.
Mainboard is the circuitboard will all the components attached to, including the memory.
I would need to know either, the brand and model of the computer, or you would need to get the brand and model of the motherboard from inside the computer, it generally reads as white text between the expansion slots and the cpu - memory or around the center area.
Graphic card for celeron d
PCI cards are hard to come by anymore. As for which is the best, the biggest question is what you plan on doing with it. If you are just doing internet surfing and basic email, any PCI video card you can find should work. If you are looking at doing any computer gaming, you may want to consider upgrading to a new PC.
What is DDR2 graphic cards ? help
Let's make this clear, There are many factors that contribute to a videocard's performance. The BUS which is the connection from the card itself to the Motherboard , though not the most important, is one of them.
PCI is extremely slow compared to PCI express and a videocard with PCI bus suffers from a strong bottleneck that makes it quite unsuitable for 3D graphics.
a PCI card is good as second display adapter to connect extra monitors to your pc: handy feature for data monitoring and multitasking but not that much as a gaming card.
Your motherboard does not have an AGP slot, but also has an Intel integrated graphic chip, so a PCI Nvidia 9400 will be quite a big upgrade, but don't expect high gaming performance...
furthermore Graphic memory speed has a big impact on performance, but size does not.512MB DDR2 is a big but slow memory and 1GB I can say it's totally useless, you need to use a resolution way over full HD to take advantage of it, but a PCI card performs really bad on that.
Which is the BEST graphic card for celeron d 325
For 99.99 on newegg you can get a Sparkle 1GB GeForce 9400 GT, DX10, 550 MHz Core Clock, Dual 400MHz RAMDAC, Shader 4.0...
The model# is SP94GT1024D2L-HP
Neweggs Link for this card is:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814187058Sparkle's Link for Product Info is:
http://www.sparkle.com.tw/product_detail.asp?id=94&sub_id=273Asking which of anything is the best is really a matter of opinion, but as far as the hardware capabilities for an older standard card go, this one has to be as good as it gets. (Actually, I'm a pretty impressed...I didn't know any PCI card could do what this does. Although it won't stand up to the bus speed of a PCIe card, or even an AGP card, if all you have is a PCI slot, this is your card!)
