20 Most Recent
Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft. Conquest Side-By-Side Refrigerator w/ In-Door-Ice Ice Dispensi... Questions & Answers
Icemaker on side by side not working
Change out your ice maker. If your icemaker has worked for 6 years, you got lucky! They normally have to be changed out every couple of years. We have an unlimited inventory of appliance parts for Whirlpool, so please call us to send your parts out and we'll get them out right away!
There is a flashing #6 in a circle above the
Mine did the same thing today and I just got off the phone with Whirlpool and they said it just means that the 6th Sense technology is activated. If you put a bunch of warm food in the refrigerator or leave the door open for a while, the 6th Sense technology kicks on to return the refrigerator to the set temperature. The flashing 6 should go away once it gets back to the right temperature.
Light is off in fridge and the bulb is NOT burned out
first unplug the machine then:
check the lamp scoket for flattened metal bars
if they are not touching the bulb pull them up to contact the side and, bottom of the lamp base replace the bulb and plug the machine in then:if that didn't work; if you can substitute another new identical bulb then: check again next check for a broken door switch
