20 Most Recent Brother DCP-8040 Copier Questions & Answers
DCP 8045D Display says Hex Dump Load - What does
I resolved the " Hex Dump Mode" problem Step1: switch off powerStep2: press and hold Stop/Exit ( Red Color Key ) switch on power supply .......now no " Hex Dump Mode" problem
7/3/2013 7:00:45 PM • Brother DCP-8040... • Answered on Jul 03, 2013
Paper jam error although no
Verify the paper exit actuator and sensors.
1/5/2012 5:32:05 PM • Brother DCP-8040... • Answered on Jan 05, 2012
I have a Toshiba 3560
Check the paper exit actuator and sensor.
1/5/2012 5:30:46 PM • Brother DCP-8040... • Answered on Jan 05, 2012
"Check Paper - Reload Paper" error with no obvious paper problems
Check the paper end actuator in the paper tray.
1/4/2012 7:20:12 PM • Brother DCP-8040... • Answered on Jan 04, 2012
2answers
My machine in the display
machine error 71 "Scanner motor does not synchronize with the reference clock."
Check:• Scanner motor
7/8/2011 3:31:28 PM • Brother DCP-8040... • Answered on Jul 08, 2011
2answers
Error code 6a
the fuser will need to replace
5/30/2011 6:38:19 AM • Brother DCP-8040... • Answered on May 30, 2011
HI, IT SAYS ERROR 6A AND I DONT KNOW WATH TO DO
Go to www.brother.com to get user manuals.
2/16/2011 12:25:01 AM • Brother DCP-8040... • Answered on Feb 16, 2011
HL-2140 Printer: drum light is
Drum light blinks because drum unit life is near to end.And that drum light blinking is indicating to replace the drum unit.For procedures on how to replace the drum unit,please click on the link below:--- http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000054/faq000154_036.html?reg=us&c=us&lang=en&prod=hl2140_all&Cat=7 -------------- If you have already replaced the drum unit,but still the drum light is blinking,then in that case the drum counter needs to be reset.To get the drum counter reset procedure, please click on the link below;--- http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000300/000055/faq000355_017.html?reg=eu&prod=hl2140_all&c=eu_ot&lang=en --------------- This should help.Thanks.Helpmech.
1/26/2011 4:55:11 PM • Brother DCP-8040... • Answered on Jan 26, 2011
What model toner for the DCP 8040
Hello
The Brother DR-510 Compatible Printer Drum ( Brother DR510 ) is used for the Brother DCP 8040 Laser Toner Printer.
For more information visit http://www.priceless-inkjet.com/cartridges.BrotherDCP8040.html or
http://www.inkcarts.com/brother-dcp-8040.html
Hope this helps, if so do rate the solution
1/19/2011 11:28:31 AM • Brother DCP-8040... • Answered on Jan 19, 2011
My light status is green,but
I supose the keybord of that Brother DCP causes this problem. Turn off the machine and try it again. If it does not work afterwords, the machine needs an new keyboard I am afraid.
1/3/2011 4:01:15 PM • Brother DCP-8040... • Answered on Jan 03, 2011
My DCP 8040 IS BLINKING
Type "99" and press enter, or just power down and back on again.
1/1/2011 11:18:50 PM • Brother DCP-8040... • Answered on Jan 01, 2011
How do I replace the
open the front cover and remove the drum unit and install the drum, like you see in this picture:
12/28/2010 9:04:29 PM • Brother DCP-8040... • Answered on Dec 28, 2010
CHANGE DRUM SOON
You will need to replace the drum soon. Once the drum life ends you will no longer be able to print.
The model drum you need is DR-510, It goes for anywhere between 175-250 dollars, depending where you buy.
10/26/2010 1:32:35 AM • Brother DCP-8040... • Answered on Oct 26, 2010
Machine advising change ink cartridge which has
remove the toner cartridge on the side wall inside the printer on the right there are 4 wires that stick out to make contact with the contacts on the side of the toner make sure that these are not bent and stand straight out. remove toner and reseat the toner to the drum unit and reinstall
10/4/2010 4:31:55 AM • Brother DCP-8040... • Answered on Oct 04, 2010
2answers
BROTHER DCP 8040
This error means that the Main motor is not synchronising with the reference clock.
This can be caused by several things...
  1. Could be a faulty motor.
  2. A faulty Engine Circuit Boaard.
  3. Fault on the Main PCB.
  4. A siezed Drum unit.
  5. Something seized up in the drive train.
Try to get it to start up with the Drum unit removed, if it does the initial rotations OK with no Drum unit installed, then try a new Drum unit.
Failing that, you will need to dismantle and inspect all the drive train and motor assemblies.
Good luck.
9/22/2010 4:42:48 AM • Brother DCP-8040... • Answered on Sep 22, 2010
2answers
To get reset code for errors on brother dcp 8040
6E
Heater temperature does not go up enough.
(Slower temperature rise rate than 2°C/5
sec. is detected.)
To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays “MAINTENANCE" on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry from the keys.
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
If again 6E occurs try to check the halogen lamp or power supply PCB.Contact authorized technician to do this checking.
9/9/2010 3:45:45 PM • Brother DCP-8040... • Answered on Sep 09, 2010
Brother DCP-8040 Copier Logo
60 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
dcp 8045d display says hex dump load
  • Office Equipment & Supplies
