20 Most Recent Panasonic TH-42PWD8 42 in. EDTV-Ready Plasma Television Questions & Answers
0answers
0answers
How to tune
Be the first to answer 2/24/2014 3:23:53 AM • Panasonic... • Posted on Feb 24, 2014Be the first to answer
HPC Monitor won't change input
Try a replacement remote control. A good one is a Philips Universal which can be found at Walmart or Right-aid. Around $14 bucks, and is very modern and up to date for just about all flat panel sets. (It's also a learning remote, so it will learn remotes).
2/2/2014 10:18:33 PM • Panasonic... • Answered on Feb 02, 2014
I have a panasonic plasma
The factory diagnostic for an 8 blink error code is: Driver SOS 3 SS-Board / SS2-Board; SS FPC Detect; SS Energy Recovery Circuit. Basically it means that the current absorbed by the X-Sus board is too high. It looks like this
http://www.discount-merchant.com/PANASONIC-TNPA3544-X-Sustain-Z-Sustain-Board-p/1042654.htm
You will need to open the tv and check the connections to this board and all the components on it. Also check the filtering capacitors from the power output line that powers this board.
If you can't find anything wrong then the entire board will have to be replaced.
11/11/2013 6:47:50 AM • Panasonic... • Answered on Nov 11, 2013
0answers
2answers
Pana TH-52PWD8UK. No picture, flashing red LED on front panel
Thanks for the quick answer. I purchased the set in 2005 and it lives outside under an overhang on my patio in humid South Florida. Unfortunately, I couldnt count the red flashes before it went completely dead. Think it was 4or 5. This would correspond with a possible fuse failure on the Power supply. I bought the online service manual, I just wish I knew what to do with it!! The fuses both seem to check out ok on a continuity check. any ideas? Thanks, Charlie
7/9/2011 5:02:46 PM • Panasonic... • Answered on Jul 09, 2011
0answers
Phillips 30FW5220/37 (hotel use originally) Its
Hi Peter
I`m going to help you with your tv but first;
Did you try the component(Ypbpr) input ?
And what is the model number of your dvd?
5/23/2010 11:32:30 PM • Panasonic... • Answered on May 23, 2010
I bought a Panasonic 42
If you cannot find the remote control at all, you will need to reprogram the EPROM IC. This IC is inside the tv, with numbers starting or in between 24c02.... Please contact any qualified tehnican for further help. The IC i mentioned is programmed and at present it is locked through Hotel Mode. Also try to look RESET switch, to reset the whole unit. Thanks
5/15/2010 5:11:05 PM • Panasonic... • Answered on May 15, 2010
Um...well i connected an xbox 360 console to your
if it a flat screen tv i would recommend u use a HD tv wit ur xbox
7/17/2009 4:06:11 PM • Panasonic... • Answered on Jul 17, 2009
We have a Pensonic led 3216 led cut, when we try to open it the screen is all black how to fix it? how to do a reset n the tv
Not totally sure what your asking but I think your saying your LED lamps aren't working, if that's the case replace them
10/15/2021 10:33:14 PM • Panasonic TH... • Answered on Oct 15, 2021
Panasonic TH-42PWD8 42 in. EDTV-Ready Plasma Television Logo
22 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
TH Panasonic
  • TH Panasonic
Most Popular Question
hpc monitor change input
  • Televison & Video
