20 Most Recent HP DVD1040i 20x Super Multiformat Dvd Writer, Internal Burner Questions & Answers
2answers
A freind let me borrow
You will need Nero burning software. It will after the normal burn show you a screen where you place the image you want to burn for lightscribe. Another failing with lightscribe is that you must have lightscribe discs!
5/19/2015 7:05:58 PM • HP DVD1040i 20x... • Answered on May 19, 2015
WHAT LEADS DO I NEED TO CONVERT MY HP DVD1040 SUPER MULTI DVD WRITER FOR EXTERNAL USE
Hi , You can buy a mobile enclosure for the dvd writer with a 12 V power adapter . Here is an example :http://eu.startech.com/HDD/Enclosures/USB-to-Slimline-SATA-CD-DVD-Optical-Drive-Enclosure~SLMSOPTB: Regards .
11/2/2014 6:21:55 PM • HP DVD1040i 20x... • Answered on Nov 02, 2014
I have an HP dvd1040
there should be a small pinhole on the front of the drive.
insert the end of a paper-clip straight into the hole, you should feel a little resistance. push in a bit until the drive bay cracks open. use your fingers to pry it the rest of the way open.
7/12/2014 11:50:45 PM • HP DVD1040i 20x... • Answered on Jul 12, 2014
My dvd burner won't read a disk or write to a
You could pay a technician $40 to $60 to "trouble-shoot", and maybe it still won't work.
Or, you could replace it for $40.
So, much cheaper just to replace it -- you don't need to buy a new one from HP, unless the price is good.
9/1/2013 8:49:09 PM • HP DVD1040i 20x... • Answered on Sep 01, 2013
Vaio vgn-ns110e dvd will not read any disc please help
Clean the laser pickup unit, by inserting a lens cleaner disc into it. If it do not hep you, replace the laser pickup unit.
4/13/2012 5:10:39 AM • HP DVD1040i 20x... • Answered on Apr 13, 2012
0answers
Dvd clashes witm my software of my printer
On the back of the drive is a jumper for M (master) S (slave) CS (cable select)
It sounds like that may be in the wrong position.
If you have two devices trying to be Master or two trying to be slave that will make boot up very slow or not at all.
Double check how the cables and jumpers are arranged.
11/3/2011 3:52:56 PM • HP DVD1040i 20x... • Answered on Nov 03, 2011
A friend bought me a HP dvd 1040e External 20x
Burn whatever you want,, so long as the disc are labeled as Rewritable (RW on the disc) To make it easy use Nero express or google"free Burners"Windows also heas a free burner.
10/22/2011 5:31:28 PM • HP DVD1040i 20x... • Answered on Oct 22, 2011
I need the drivers for
FOR ANY ONE WITH SIMILAR OR SAME PROBLEMGET all drivers and templates etc at:http://www.lightscribe.com/support/ Check it out, worked to recognize my HP Super Driver. Download it all, include the diagnostic. Anybody who has a lightScribe should beable to use this.
10/21/2011 9:39:23 PM • HP DVD1040i 20x... • Answered on Oct 21, 2011
My computer wont regonize my dvd writer so I can
The solution to your problem is probably mentioned in this MS Knowledgebase article:
http://support.microsoft.com/kb/982116
Good luck; hope this helps to solve your problem.
4/25/2011 3:10:26 PM • HP DVD1040i 20x... • Answered on Apr 25, 2011
I am having trouble burning
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps don
2/25/2011 6:06:19 AM • HP DVD1040i 20x... • Answered on Feb 25, 2011
My HP DVD 1260i just broke up my cd after turning
how it wll change read speed hp dvd 1260i
2/19/2011 6:50:35 AM • HP DVD1040i 20x... • Answered on Feb 19, 2011
2answers
How do I reset the region code after the last
you need to uninstall the software then reinstall it... then play a dvd then you have the options again If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
2/11/2011 2:05:59 AM • HP DVD1040i 20x... • Answered on Feb 11, 2011
I cant find Firmware -
Hi ,
You can find some support here :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=lpg40607
It seems also a solution was found here : It's the same firmware as for Liteon drive :
http://forum.rpc1.org/viewtopic.php?f=12&t=45689
And you can download it from here :
http://codeguys.rpc1.org/firmwares.html
I hope this will help you .
Best regards .
1/28/2011 5:15:43 PM • HP DVD1040i 20x... • Answered on Jan 28, 2011
I have a Hp Pavilion dv6000 and iam having problem
hi friend, you should buy a DVD lance cleaner DVD. which is avilable in your electronic market. use it.bcoz, your dvd lance have dust on it.
if, it again give you same error then, goto your nearest service center.
Regards: Rakesh
1/26/2011 9:39:47 AM • HP DVD1040i 20x... • Answered on Jan 26, 2011
Is the HP dvd1040i compatible
YES IT IS....
1/17/2011 10:21:15 PM • HP DVD1040i 20x... • Answered on Jan 17, 2011
HP DVD1040i 20x Super Multiformat Dvd Writer, Internal Burner Logo
Popular Tags
69 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
leads need convert hp dvd1040 super
  • Computers & Internet
