20 Most Recent
Sony Ericsson V600i Cellular Phone Questions & Answers
I have a Sony Ericson
Hi.
If you get the Wrong SIM Card message, then it is not a matter of security code. When you enter the security code, you get a code request at start.
About possibility that the phone has locked back to single SIM, that is also highly unlikely. If the phone was bricked or unlocked to all SIM cards, to lock it to a SIM service again, you have to flash the phone firmware, and this is not an operation that may occurr by accident.
When you get Wrong SIM message, usually the SIM card is malfunctioning. In some case you have a malfunctioning phone with a problem in SIM card slot contacts.
Do the following.
Remove the battery and the SIM, located in a slot behind the battery, blow the SIM slot with some canned air, and put back the SIM. Power drain will reset the phone and blowing air may remove dust that can cause the problem.
Test the SIM using a different phone, and test the phone using a different SIM. If the previous step did not help, this may reveal what part is defective.
If the SIM is working, then the problem is the phone, otherwise the SIM.
Regards.
Ginko.
Trying to upload pictures from sony ericsson v60i
is the pix on an external memory card or the phone internal card? you need a usb cable for connection of your cell to pc. if the pix are on external you will see the new drive on "my computer" on pc...if its on the phone internal you need to go to menu/settings/tools/connections...switch cell phone to data...you should see usb/data/bluetooth...now you can copy/paste or click/drag to pc....
Not activated mms,3g,
has the phone got the settings? if not go to your networks website and send the settings to the phone from there
My Sony Ericsson v600i fell hard to the floor and
I am sorry to inform you that the phone is damaged. Do you have insurance on it? Is there a warranty on it? If you do not have insurance on it do this. Get it. Find out when it actually starts covering your phone. After that period get a new one. Hope this helps, remember that these cell phones cannot be dropped, cannot be subjected to sweat or moisture. They are like babies, handle with care. Hope this helps. You can go to this link below for more information about your phone. Just copy and paste into your browser.
http://images.google.com/imgres?imgurl=http://www.mobilerainbow.org/images/mobiles/SonyEricssonv600i_1.jpg&imgrefurl=http://www.mobilerainbow.org/sonyericsson/Sony-Ericsson-V600i.html&usg=__Qy8C9Zfn2j1bMZBshyN1M_45iI8=&h=293&w=226&sz=36&hl=en&start=3&um=1&tbnid=6U_Bc92CzsI6fM:&tbnh=115&tbnw=89&prev=/images%3Fq%3DSony%2BEricsson%2Bv600i%26hl%3Den%26client%3Dfirefox-a%26channel%3Ds%26rls%3Dorg.mozilla:en-US:official%26sa%3DX%26um%3D1
Hope this helps, let me know if I can help you with anything else.
JimmyC
V600i
sony ericssion v600i phone software pro
Sms messages not able to receive
A server setting on your handset may have been changed, this would be blocking incomming messages from your server only. try using "master reset? in settings, should automatically adjust to your current server.
Good Luck
Screen
A replacement screen can be bought at most common phone repairers, i have had myne replaced due to scratching and dust on the inside. It seems to be a bit costly though, it shouldnt cost over a hundred though, could be alot cheaper.
Good Luck!
