20 Most Recent Rotel Rsp-1066 Surround Sound Processor Questions & Answers
hi
it sound to me that when you biamp and driving speaker and woofer , you are over loading the fuses , suggestions
uprate the fuses till they stop blowing
Rotel Audio... | Answered on Dec 21, 2017
Probably the EEPROM, the heart and brain of the appliance.
I had the same issue with my AIWA, could not figure out the cause, took it in, tech told me EEPROM is blown.
Not economical to repair.
Rotel Audio... | Answered on Nov 20, 2017
Your changer has lost its mind and is doing crazy things.just like mine. Software issue not repairable.. Go shopping.
Rotel Audio... | Answered on Sep 13, 2017
Try interchanging the speakers. If the right channel works, you have a problem with your speaker.
Rotel Audio... | Answered on Nov 19, 2016
Check the rest of the power supply, for example the transformer if there is no power at all. If you are getting some indication of power, check the voltage regulator circuit.
Rotel Audio... | Answered on Apr 30, 2016
Hi Awal. Interesting problem. Have you tried another pair of leads? What source are you using please, cd tuner etc? I noticed the the names for the five audio/video inputs can be customized by the user, Maybe there is a firmware issue? With the unit being surround sound Have you tried running in 2 chanels only?
Rotel Audio... | Answered on Jan 16, 2015
I'm guessing you don't know for sure that it even needs fuses. They don't go out like they used to, as everything is controlled by a microprocessor(computer within your unit). I would suggest, that you, with the power plug pulled out, use an ohm meter to be sure that each fuse is shorted. If you need further assistance, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
Rotel Audio... | Answered on Nov 19, 2014
YOU ARE NOT RIGHT IT SHOULD GIVE AT LAEST A LOW VOLUME SOUND WITH A LOT OF DISTORSION AND A CRACKING NOISE IF DOES I GUESS THAT YOU HAD THIS AMP IN A PLACE WITH A LOT OF HUMIDITY AND YOU HAVEN'T WORK IT FOR SOME TIME IF I AM RIGHT PUT YOUR AMP IN THE SUN AND WORK IT FOR 10 MIN WITH A 5 MIN BREAK LET ME KNOW THE RESULTS
Rotel Audio... | Answered on Sep 03, 2014
IF THE FUSE YOU ARE PLACING IS THE SAME TYPE AS THE ORIGINAL YOUR AMP HAS A PROBLEM WHAT YOU MUST DO IS TO SLIGHTY INCREASE FUSE BY 100 MAMPS PER TIME IF IT IS IN THE TRANSFORMER CIRCUIT YOU CAN INCRESE IT BY 2 AMP MAX IF IT IS IN THE MOSFETS CIRCUIT YOU CAN INCRESE IT BY A MAXIMUM OF 500MAMP LET ME KNOW THE RESULTS
Rotel Audio... | Answered on Jun 14, 2014
Tip
ROTEL QUALITY
ROTEL AMPS GET HOT QUICKY IN ORDER NOT TO HAVE PROBLEMS DONT WORK THEM WITH NON BRANDED PREAMS OR MIXERS
on Jun 14, 2014 | Rotel Audio Players & Recorders
I do not know anything about your brand or market, but I have had good success with replacement remotes at http://www.replacementremotes.com/
They have a very wide selection of mostly refurbished remotes.
Originally supplied with RSX 1058 is this:
http://www.replacementremotes.com/ROTEL/Buy-RR-1061-RR1061-Audio-Remote-Control.html
Rotel Audio... | Answered on Jan 18, 2014
Rotel Rsp-1066 Surround Sound Processor Logo
0 questions posted
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Rotel Audio Players & Recorders
Most Popular Question
rotel rhb 10 amp not firing up anymore
  • Audio Players & Recorders
