20 Most Recent Philips 42PFL7432D 42 in. LCD Television Questions & Answers
My Philips 42' LCD HDTV,
T con board is responsible for what you finally see on set screen as well as any anomalies. Check it out. TV Parts Universal TV Stands DLP Chips ShopJimmy Sears Online In Store Shopping Appliances Clothing More
9/21/2017 12:48:31 AM • Philips... • Answered on Sep 21, 2017
I have a philips lcd tv model 42PFL7332D/37.
Tv turn on now,u just get a flashes of a picture only a few sec. than dies and have sound left only?Yes,than those 2 long boards that call the LCD inverter boards are dead.These 2 long LCD inverter boards job are to help the LCD picture screen panel to have a backlight to produced the picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
4/30/2016 6:32:05 PM • Philips... • Answered on Apr 30, 2016
0answers
Philips 42pfl7432d/37 has no picture or sound. Power light comes on for a few seconds
It sounds like you have done some research on this issue. My suggestion is that the power supply is supplying the dc voltages to the inverter boards it is just that the inverters are not working, it is suggested that you replace both the master and slave inverters at the same time, You might want to try using a flash light or other light source and shine on screen and then get up real close and see if you can make out the images, and if this enables you to see the images and it appears that everything is working except the back lights then I would feel comfortable replacing both inverter boards. Hope this helps.HID KITS.
6/1/2012 3:19:09 PM • Philips... • Answered on Jun 01, 2012
No sound no picture what is wrong
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_30_2012_2_14_13_pm.jpgleft one is good and right is bad5_30_2012_2_15_03_pm.jpgarrows point to a number of real bad caps
5/30/2012 2:36:00 PM • Philips... • Answered on May 30, 2012
I HAVE A PHILIPS LCD TV MODEL 42PFL5432D/37 WITH
First, the used screen will be more than $300 plus shipping, new is almost impossible to get.Second, you need to get the exact model number as printed on the sticker on the LCD panel since you will have to transfer all the boards from old TV to the new panel.Parts: www.interliquidparts.comI myself will not do it. Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Parts: www.interliquidparts.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
11/12/2011 3:30:35 AM • Philips... • Answered on Nov 12, 2011
I cant find the hdmi
See image above.
9/6/2011 7:33:12 PM • Philips... • Answered on Sep 06, 2011
Need power cord
I'm sorry for the difficulties you're experiencing in getting the power cord for the TV. Please click hear to order for the original power cord directly from Philips.
Please let me know if you require any clarifications.
6/13/2011 10:17:56 PM • Philips... • Answered on Jun 13, 2011
Philip 42pfl7432d/37 has sound, but no picture,
Tv turn on now,pictures only flashes few sec. than dies have audio left only?Yes,than the tv 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
5/11/2011 12:47:10 AM • Philips... • Answered on May 11, 2011
My TV has sound and
The Master and slave inverter panels are faulty and yes this may still be under warranty. If the inverter panels (placed at both sides of the LCD panel) have "Rev 1.2" printed down one end, then they need to be replaced with Rev 1.3 panels. This is a common fault and worth contacting the manufacturer about.
3/18/2011 10:13:01 PM • Philips... • Answered on Mar 18, 2011
0answers
Phillips 42" LCD, turned off last night, turned on
LCD inverter backlight board is out 42pfl7432d/37
1/15/2011 11:44:59 AM • Philips... • Answered on Jan 15, 2011
0answers
Received new backlight inverters 6632L-0348b and
I wouldn't unless you're sure they match the particular model. Each of them are different depending on size of set. This can be verified by seial number version(ya1b, ya3b, c and so on). If you were to try this you might fry the backlight, requiring a replacement panel. They supply different voltages........Please be careful, can be lethal, 1000vdc or more........Good success, Meder's Tv
10/3/2010 3:34:15 PM • Philips... • Answered on Oct 03, 2010
2answers
Set turns itself on, scrolls
If the firmware upgrade hasn't helped then the problem is hardware - a part is faulty. By your description it appears that the main processor is functioning erratically and this can be caused by:
- overheating - you will need to open the tv and clean the inside thoroughly.
- an unstable power supply - you must open the tv and check the power source, probably the filtering capacitors have aged/failed and the output voltage is way off the recommended value.
- the processor itself is dying - you will have to replace the mainboard. Unfortunately parts for your tv can only be found at authorised repair shops, or dealers, so you will gonna have to take your tv to one.
9/30/2010 6:47:46 AM • Philips... • Answered on Sep 30, 2010
I need a replacement LCD panel for my Philips TV.
unless it's under extended or manufacturer warranty...not cost effective to replace. You can get it at partstore or shopjimmy.com if this is the case. Good success.....Meder's TV
6/27/2010 10:39:49 AM • Philips... • Answered on Jun 27, 2010
Philips 42PFL7432D 42 in. LCD Television Logo
47 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
received new backlight inverters 6632l
  • Televison & Video
