20 Most Recent Integra Dtr-20.3 THX Select2 Plus AV Receiver Questions & Answers
Usually the headphone jack has a contact that's "made" by the 'ring' section of the jack when you push in the plug, which bypasses the speaker circuit (that's what automatically silences the speakers when you plug in the headphones when there are no switches to turn the speakers on/off manually)... if the 'ring' strip got bent somehow so it's pressing against that contact all the time, it won't let the speakers' circuit come out of bypass. Look inside the jack with a flashlight... the sideways Vs that touch the 'ring' sections of the stereo headphone plug should be about in the middle of the opening... if they're pushed over too far it may require disassembly to bend them back to the proper position.
Integra Dtr-20.3... | Answered on Mar 08, 2015
You have a defective processor pcb. repair shop must change bd.
Integra Dtr-20.3... | Answered on Feb 19, 2015
The processor pcb board will need to be changed
You will have a defective processor pcb.
http://www.integrahometheater.com/faqs.php Check the connections and try a master reset?
Perform a master reset. To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode.
Integra Audio... | Answered on Jul 03, 2018
You have a defective processor pcb assembly and it must be changed.
Integra Audio... | Answered on Feb 19, 2015
You will have bad output transistors, a $124 to 150 repair in shop service
Integra Dtr-20.3 THX Select2 Plus AV Receiver Logo
10 questions posted
Top Integra Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Integra Audio Players & Recorders
Most Popular Question
integra dtr 20 3 recently getting no
  • Audio Players & Recorders
