20 Most Recent
Kaser Corporation Mambo BW MP3 Player Questions & Answers
Putting music to a DVD
You will need to use the copied film as a video source, and the music you want, in digital form, as an audio source. You will then need audio-video editing software to alter the playback speeds of one or both and mix them together.
That's going to take time, learning how to use the software. It will not be quick, or easy, but you will probably be able to find some freeware for the purpose. Free software usually has poor or no documentation, which will make learning harder..
You will need to decide what sort of output format you want, which will mostly depend on where & how you want to watch it in future. This isn't an irrevocable decision: you could save the output as, say, XVid/MP3, and convert it to video CD or any other form later. That's a separate issue..
Just remember that you are choosing to spend effort instead of money. You could always hire this done instead.
1/15/2010 8:07:49 PM •
Kaser...
Answered
on Jan 15, 2010
I HAVE DOWNLOAD MUSIC TO MP3 BUT I CANT GET ON
If you mean you can't put the MP3 files you downloaded onto the player, then you simply need to plug the player into a USB port on your computer -- either directly into the port (for some player models) or via an extension cable.
Once you've done so, the computer will "recognize" the player as a new disk drive, and assign a drive letter to it. Your computer will normally inform you via a pop-up, that it found new hardware.
Now just use Windows Explorer to drag and drop the mp3 files onto the new drive. This loads the files onto the player. Once the transfer is complete you can unplug the player, and it's ready to go.
1/15/2010 7:59:37 PM •
Kaser...
Answered
on Jan 15, 2010
No disc error even with DVD inside the player
I am sure that you have tried using another DVD.
Try putting a Music CD and see if it can read it.
In any case, even if the CD works, it looks that you have a faulty unit the laser on the drive is probably bad now but just in case it is just dirty, try to clean it with a Cleaning Disk and see if the problem disappear.
12/23/2009 5:01:22 AM •
Kaser...
Answered
on Dec 23, 2009
Kaser Mambo BW 4G mp3 player
You might try going to settings: select play mode: select dir normal and then exit. There are many different selections, but this might hold you within a specfic directory.
4/4/2008 8:29:07 PM •
Kaser...
Answered
on Apr 04, 2008
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
