20 Most Recent D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Questions & Answers
Dlink allowing Xbox 360 to connect to Xbox Live
Yep. No problem. Step by Step right here.
http://portforward.com/english/routers/port_forwarding/Dlink/DI-624/Xbox_Live_360.htm
8/28/2018 11:34:04 AM • D-Link DI-624... • Answered on Aug 28, 2018
We have two x-box 360s
put one of them in DMZ zone or use port triggering.
3/5/2018 8:06:09 AM • D-Link DI-624... • Answered on Mar 05, 2018
0answers
Dlink DIR415 must be rebooted
Try a factory reset. You this m logging into the router using your browser and select factory reset. Of course you will have to set-up your router from scratch but often this solves many issues.
1/6/2017 7:29:41 PM • D-Link DI-624... • Answered on Jan 06, 2017
2answers
Cannot access http://192.168.0.1
Check to see if the wireless device in the laptop is functional and not disabled by double clicking My Network Places and clicking Local Networks. Make sure that the wireless device you are trying to connect to has solid leds and not blinking, it would not hurt to restart the device. When it has solid leds click the wireless icon on the lower right side of the task bar, search for available networks, choose the one to connect to, and click connect. If everything is functioning correctly it will connect. BPCS
7/7/2015 1:59:09 AM • D-Link DI-624... • Answered on Jul 07, 2015
DI624 will not work. All 4 LAN lights permanantly on with no cables connected
Yes it could be faulty, especially if it the router is not protected with a surge protection power board.
1/23/2013 1:36:57 AM • D-Link DI-624... • Answered on Jan 23, 2013
Open port 80 in dlinkdi624
http://www.manualowl.com/m/D-Link/DI-624S/Manual/156171
read this carefully hope your problem after read this article thats a manual dlink 624
9/23/2011 7:58:08 PM • D-Link DI-624... • Answered on Sep 23, 2011
2answers
How can I change my
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router) (unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the following: -
1.On the left-hand side, under Setup, click "Wireless Setup" 2.Under "Wireless Security Mode", select your desired encryption method (preferably WPA2-PSK)
3.Choose/change the Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
Also, for additional security, you may try the followng steps: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above step would prevent unauthorized access to your router)
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback and approciate the efforts.
CreativeTECH
4/3/2011 10:56:42 PM • D-Link DI-624... • Answered on Apr 03, 2011
2answers
How to set security?
Click on the link below for a step by step on how to install security.
Security Gateway/di624
It is on page 7.
Hope I was of help.
3/27/2011 7:38:30 PM • D-Link DI-624... • Answered on Mar 27, 2011
Having trouble connecting Xbox live.
Is the router already setup and working? Do you have anything else that successfully connects to it "wirelessly", like a laptop or desktop or smartphone? If the answer is yes, here's how to setup the 360 to connect to your router:
1. Turn on the console and navigate to the wireless settings screen. On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
2. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
3. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
4. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead.
5. Save your settings and verify the network is functional. On the Xbox 360, use the "Test Xbox Live Connection" option.
Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
What You Need: Active Xbox Live subscription (to access services)
edited from here: http://compnetworking.about.com/od/wifihomenetworking/ht/xbox2wifirouter.htm
3/5/2011 6:50:54 AM • D-Link DI-624... • Answered on Mar 05, 2011
Poo
> poo
That smells. Please report the symptoms that caused the problem.
2/21/2011 1:18:49 AM • D-Link DI-624... • Answered on Feb 21, 2011
Hi I have a DI624 that worked fine...one day power
If you have powered it off and used the reset, I'm afraid it's toast. Was your power adapter for the same router, they are not interchangeable?
12/22/2010 1:21:37 AM • D-Link DI-624... • Answered on Dec 22, 2010
My dsl - 2640U router
You can install Router Commander program that:
1. Prevents router from rebooting
2. Forwards ports automatically
10/4/2010 2:08:59 PM • D-Link DI-624... • Answered on Oct 04, 2010
I am not able to access my work L2TP VPN from home
disable the firewall and antivirus in your system and check it
Thank you
7/24/2010 9:25:37 AM • D-Link DI-624... • Answered on Jul 24, 2010
Not able to connect the wireless internet
but are you able to connect with the wire?
if you do.
have access to the dlink router and set upt th econnection via DHCP
if you dont know how to do that contact me back and ill give you the instructions.
4/27/2010 7:23:52 PM • D-Link DI-624... • Answered on Apr 27, 2010
HI HAVING TROUBLE SETTIG UP THE ROUTER
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
2/15/2010 3:45:11 AM • D-Link DI-624... • Answered on Feb 15, 2010
D-Link DI-624 Air Plus XtremeG Wireless 108G Router (790069250842) Logo
Popular Tags
82 questions posted
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
dlink allowing xbox 360 connect xbox
  • Computers & Internet
