20 Most Recent Denon AVR-1613 Receiver Questions & Answers
Does the display ever come on when you hit the power button?
Denon AVR-1613... | Answered on Aug 11, 2014
you may have pushed mute- try pushing it again! good luck!
Denon AVR-1613... | Answered on Nov 04, 2013
I find the best way to connect any equalizer is to connect via the tape monitor sockets, assuming that the AVR has one. From the equalizer in and out sockets - connect the Eq OUT to Tape IN on the AVR. And Eq IN to Tape OUT on the AVR.
Some AVR don't allow connections, due the equalizer interfering with Surround Sound systems. If you can connect switch off the equalizer when listening to Dolby or other surround formats, as it will spoil the sound.
Denon Audio... | Answered on Oct 12, 2019
Google (denon)(al24)(manual) without parens OR contact Denon directly with your request.
Denon Audio... | Answered on Sep 28, 2019
Hold together VIDEO SELECT and TUNER button while OFF and push button to ON.
Denon Audio... | Answered on Sep 23, 2019
Hi Ray Lynam, for what you say, you could have a problem with the speaker output
I suggest you remove the cover and look for two F2 and F3 fuses of 4Amp each that correspond to the output of the speakers, check if they are burned, if so replace them, ONLY FOR FUSES OF EQUAL VALUE 4AMP, do not put more value because you could produce major damage, test the equipment and if they burn again, then if you have problems at the exit stage
In this case, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Ray Lynam, por lo que comentas, podr?as tener problema en la salida de parlantes
Te sugiero retirar la tapa y buscar dos fusibles F2 y F3 de 4 Amp cada uno que corresponden a la salida de parlantes, controla si est?n quemados, si es asi reemplazalos, SOLO POR FUSIBLES DE IGUAL VALOR 4 AMP, no pongas de mayor valor porque podr?as producir un da?o mayor, prueba el equipo y si se vuelven a quemar, entonces si tiene problemas en la etapa de salida
En este caso busca un servicio t?cnico especializado
Espero que puedas resolver el problema
Saludos Franco Dosil
https://www.hifiengine.com/manual_library/denon/dra-350.shtml
Denon Audio... | Answered on Sep 17, 2019
I would guess it's the Surround Sound mode button. Various modes in Surround Sound do not use all 5 speakers. Often the button pressed repeatedly changes between the modes. So if you press it again it might restore the sound mode to the one you had. I can't be more specific as you did not give the model number.
You could try the Denon website to see if they have a free PDF of the user manual, if you have lost it. You will need the model number for that though.
Denon Audio... | Answered on Jul 22, 2019
Denon AVR-1613 Receiver Logo
16 questions posted
Popular Products
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Audio Players & Recorders
Most Popular Question
off button keep flashing red fast avr
  • Audio Players & Recorders
