20 Most Recent Infinity 475A Car Audio Amplifier Questions & Answers
Where is the fuse for infinity gold amp 1996 Jeep Grand Cherokee
Not sure if it's the same but I have a 99 grand, and the fuse is in the amp under the back seat on the passengers side
4/30/2017 6:31:31 PM • Infinity 475A... • Answered on Apr 30, 2017
Hello I have a 475a power amp hooked in my car. It
Where do you have the amp located? if it gets too hot it will shut down, compare to where you have it to where your brother has his.
4/30/2017 6:26:56 PM • Infinity 475A... • Answered on Apr 30, 2017
I was driving down the road the other day and my
Sounds like you have no signal going to the amp. Check th RCAs.
9/22/2010 11:40:27 PM • Infinity 475A... • Answered on Sep 22, 2010
Accidentally got the power and
I would try it, if you haven't already, without any outputs (Speakers) hooked up, just the amp and the power...if the fuse goes again, it has an internal problem.
9/7/2010 2:17:14 AM • Infinity 475A... • Answered on Sep 07, 2010
I got a mistu 2001 eclipe the amp burn out i
check your wiring's
6/8/2010 12:28:55 AM • Infinity 475A... • Answered on Jun 08, 2010
Is there a way to reset an infinity 475a car audio
pull out the fuse wait a while then plug it back in
4/9/2010 4:41:54 AM • Infinity 475A... • Answered on Apr 09, 2010
I have a 1996 jeep and it has an infinity gold
Most likely no. The parts for the amp and not easily obtained and some take special tools to repair. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
3/31/2010 2:35:25 PM • Infinity 475A... • Answered on Mar 31, 2010
I have 2000 Mits Eclipse with a Infinity amp MR
contact Eric @ Capital Audio & Electronics Repair in Tallahassee,Fl. we repair all namebrands & all models
3/20/2010 8:57:22 PM • Infinity 475A... • Answered on Mar 20, 2010
My amp keeps going in and out of protect mode
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your amp is probably OK. The volume is either set to high or the speaker load is to low of an impedance. Remember 2, 8 ohm speakers connected is the same as 1, 4 ohm speaker. Another possibility is that you do not have enough battery power coming to the amp itself. A simple rule I use is take the watts and divide by ten, that will give you an approximation of the amps needed on a 12 volt system. This takes into account some of the losses in the amp, but it is only an approximation. For example 300 watts RMS is 30 amps, which will require a number 8 wire to keep the losses at a minimum. You can check wire drops on the web.
Good Luck,
Gilshultz
11/30/2009 6:47:11 AM • Infinity 475A... • Answered on Nov 30, 2009
I installed a 475a to my door speakers and when i
You blew the speakers. The speakers were probably not made for that much power and the voice coil blew. If they were stock speakers, then they are defenetly blown. Stock speakers are not made for much power at all, and will more than likely blow with any extra power given to them at all.
10/24/2009 7:55:33 PM • Infinity 475A... • Answered on Oct 24, 2009
I just bought a 98 concorde lxi and no sound
Hello georgouseyes,
The problem could be in the output from your receiver to the amp or in the amp itself.
First check to see if the amp powers up. If it doesn't, check the main power fuse (usually located under the hood near the battery). Also check the power and ground connections on both ends.
If the main fuse checks OK, check both onboard fuses. There's 2 35A fuses on the far right.
If the amp powers up OK and the onboard fuses are not defective, it's possibly the output from your receiver or line output converter. Replace the RCA cables with a known good pair. If there's still no sound, I'd suspect that the amp itself is defective.
Hope this helps.
10/17/2009 6:59:02 AM • Infinity 475A... • Answered on Oct 17, 2009
Sound loss
bad system cofiguration too much load on rea amp
6/26/2009 3:53:56 AM • Infinity 475A... • Answered on Jun 26, 2009
Infinity 475a amplifier makes a high tone
Your stereo is picking up alternator whine. If you're good, you can make the motor fit with the song... kidding.
you can purchase a noise filter that will fit on the ground line of the alternator.... here's a few to scope out online
this will get it out for ya...
k
5/31/2009 12:36:38 AM • Infinity 475A... • Answered on May 31, 2009
Crossover issues?
if only highs are comin through subwoofer then check pf switch on amp then adjust crossover frequency to 80hz hope this helps
5/22/2009 4:14:00 AM • Infinity 475A... • Answered on May 22, 2009
Bose amlifier
Power wire is usually yellow or red. A cheap test light from the parts store will tell you. The remote wire is almost alway solid blue. A volt meter will tell you for sure. Remember,the remote wire is very low voltage.
5/19/2009 12:53:27 PM • Infinity 475A... • Answered on May 19, 2009
Protect mode on 475a
Yes if your wires are to small they dont supply enough power to the amp and it will shut down..Also the ground..Check all connections for tightness and that none of the wires are touching or grounding out...Hope this helps you and have a great day I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
4/2/2009 6:43:14 PM • Infinity 475A... • Answered on Apr 02, 2009
Infinity 475A Car Audio Amplifier Logo
31 questions posted
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Sean Wright
Sean Wright
Steve Sweetleaf
Steve Sweetleaf
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Infinity Car Audio & Video
Most Popular Question
accidentally got power
  • Car Audio & Video
