20 Most Recent KLH R3100 Remote Control Unit Only Questions & Answers
disconnect offending unit. then play see if same response occurs on the alleged normal unit using the offending cable interchange cables see if you get same result. Means it's bench repair ,internal electronics require specialist equipment to locate the offending item.
KLH Audio... | Answered on Oct 31, 2018
You could check it by having the unit switched on a touching each of the pins of the device with an insulated tool. Making certain you don't short any of the pins together. You should hear a buzz on each channel. If you get nothing on the right then it could well have gone.
However that is a lot of messing about, as the device can be purchased for around £12, it could be easier just to replace it and see if that cures it. After all it is the device that does most of the work, so the chances are it's gone!
KLH Audio... | Answered on Oct 01, 2018
If you can post a picture of the fuse it might help in tracking one down.
However I should point out that fuses rarely blow on their own. And one blown is a sign of a serious overload, probably in the main amp or power supply section.
KLH Audio... | Answered on Jul 09, 2018
Fixya does not do appraisals.
KLH Audio... | Answered on Mar 17, 2018
This is what is called a 'passive radiator'. It helps the bass response of the system. It is an adaptation of a bass reflex speaker enclosure. Try this link at wiki: Passive radiator speaker
KLH Audio... | Answered on Dec 16, 2017
That is sometimes called a "radiator". It's a speaker cone that moves opposite the main woofer and produces sound waves out of sync with the powered woofer. Very sophisticated piece of audio engineering intended to enhance bass response.
KLH R3100 Remote Control Unit Only Logo
2 questions posted
Popular Products
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • KLH Audio Players & Recorders
Most Popular Question
find downloadble manual free
  • Audio Players & Recorders
